SOS disconnect
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Fri Jul 6 08:31:56 EDT 2007
> -----Original Message-----
> From: Charlton Purvis [mailto:cplist at secondcreek.org]
> Sent: 06 July, 2007 8:20 AM
> To: Kralidis,Tom [Burlington]; MAPSERVER-USERS at LISTS.UMN.EDU;
> 'Yewondwossen Assefa'
> Subject: RE: [UMN_MAPSERVER-USERS] SOS disconnect
> Hi, Tom and Assefa:
> > N.B. are you intentionally setting observedproperty to a URL in the
> > mapfile? Note that it can also be a plain old string, etc. :)
> Yes, that's intentional. It's not the most readable thing, I
> agree, but that's the way this particular booger needs to be done.
> > When I try:
> http://sos-web.tamu.edu/sos-cgi/madis?service=sos&request=GetObservati
> > on
> &version=0.0.31&offering=ndbc_44029&format=application/com-xml&observe
> > dP
> roperty=http://marinemetadata.org/cf%23sea_surface_temperature&eventTi
> > me
> =<gml:TimePeriod><gml:beginPosition>2007-06</gml:beginPosition><gml:en
> > dP
> > osition>2007-07</gml:endPosition></gml:TimePeriod>
> > It seems to work; mind you there looks to be only one
> record. How are
> > you passing the time query?
> Oh. Interesting. One record is correct. This particular
> table only holds the latest obs for a given sensor / platform
> combo. I was originally trying to pass &time=yyyymmddThhmiZ
> and that caused it to be unhappy. But Example2 from
> http://mapserver.gis.umn.edu/docs/howto/sos_server passes a
> time param, so maybe I'm doing something wrong, or should I
> stick w/ the syntax you described above?
Thanks for pointing this out, Charlton; eventtime is the supported
parameter for passing temporal. I've changed this on the howto page.
> Assefa, MapServer version 4.10.2.
> > > The getcaps behind all of this is here:
> > > http://sos-web.tamu.edu/sos-cgi/madis?service=sos&request=getc
> > apabilities&ve
> > > rsion=0.0.31.
> Tom, you're right, the GetCaps works fine, but that's because
> I took out a layer that seemed to set the GetCaps over the
> edge. I'll put together a barebones .map and pass around
> that will hopefully be able to reproduce the problem.
This would be great!
> Many thanks, fellas!
> Charlton
