query by rect
Eduardo Zenaide ezenaide at GMAIL.COM
Tue Jul 10 16:05:21 EDT 2007
ok, after trying a lot, it worked with auto_rect. don't know where the error
was but it's working. i restarted apache and windows too.
thanks anyway.
2007/7/10, Eduardo Zenaide <ezenaide at gmail.com>:
> hi list.
> i'm using some javascript to do a query. it gets information from html
> combo boxes.
>        function determinaQSTRING() {
>         //converting everything into variables:
>         //host information:
>         var hostPar = "http://localhost:82/zaal/al.php?";
>         //keymap:
>         var keymapPar = "KEYMAPXSIZE=100&KEYMAPYSIZE=75&";
>         //fixed layers:
>         var layerFixa = "Limite_Estadual_AL=Y&grid=Y&";
>         //get layer used on query from combobox:
>         var layer = document.pesquisa.layersList.value;
>         var modePar = "&CMD=QUERY_POINT&INPUT_TYPE=submit&";
>         //map image attributes:
>         var imagePar = "imagewidth=760&imageheight=570";
>         //get query string from combobox:
>         var queryEntry = document.pesquisa.nameList.option;
>         //get operator from combobox:
>         var operador = document.pesquisa.operadores.value;
>         //get coordinates from combobox:
>         var allComboValue = document.pesquisa.nameList.value;
>         var allComboValueArray = allComboValue.split(',');
>         var minx = "minx=" + allComboValueArray['0'] + "&";
>         var miny = "miny=" + allComboValueArray['1'] + "&";
>         var maxx = "maxx=" + allComboValueArray['2'] + "&";
>         var maxy = "maxy=" + allComboValueArray['3'] + "&";
>         //query string:
>         document.pesquisa.qstring.value = "(\"[NOME]\" "+ operador +" /"+
> queryEntry +"/)";
>         //reload map:
>         window.opener.document.location = hostPar + keymapPar + layerFixa
> + layer + "=Y&" + minx + miny + maxx + maxy + imagePar + modePar +
> "INPUT_COORD=390%2C285%3B390%2C285";
> ok, its very ugly, but i though it would work. my problem is in the type
> of query.
> it only does query by point, i'm trying to use query by rect.
> already tried auto_rect but didn't work too.
> what can i do?
> thanks in advance :)
> Eduardo Zenaide
Eduardo Zenaide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070710/c77b90ee/attachment.html
