SOS disconnect
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue Jul 10 16:44:50 EDT 2007
Charlton,
I was able to reproduce the GetCapabilities issues with 4.10.2. The
bugs were corrected in the current svn version (to be 5.0). I also back
ported them in the 4.10.x branch in case there is a 4.10.3 release. If
possible please upgrade to either versions and so the tests.
http://trac.osgeo.org/mapserver/ticket/1938
http://trac.osgeo.org/mapserver/ticket/2146
Best Regards,
Charlton Purvis wrote:
> Hi, Tom and Assefa:
>> N.B. are you intentionally setting observedproperty to a URL in the
>> mapfile? Note that it can also be a plain old string, etc. :)
> Yes, that's intentional. It's not the most readable thing, I agree, but
> that's the way this particular booger needs to be done.
>> When I try:
>> http://sos-web.tamu.edu/sos-cgi/madis?service=sos&request=GetObservation
>> &version=0.0.31&offering=ndbc_44029&format=application/com-xml&observedP
>> roperty=http://marinemetadata.org/cf%23sea_surface_temperature&eventTime
>> =<gml:TimePeriod><gml:beginPosition>2007-06</gml:beginPosition><gml:endP
>> osition>2007-07</gml:endPosition></gml:TimePeriod>
>> It seems to work; mind you there looks to be only one record. How are
>> you passing the time query?
> Oh. Interesting. One record is correct. This particular table only holds
> the latest obs for a given sensor / platform combo. I was originally trying
> to pass &time=yyyymmddThhmiZ and that caused it to be unhappy. But Example2
> from http://mapserver.gis.umn.edu/docs/howto/sos_server passes a time param,
> so maybe I'm doing something wrong, or should I stick w/ the syntax you
> described above?
> Assefa, MapServer version 4.10.2.
>>> The getcaps behind all of this is here:
>>> http://sos-web.tamu.edu/sos-cgi/madis?service=sos&request=getc
>> apabilities&ve
>>> rsion=0.0.31.
> Tom, you're right, the GetCaps works fine, but that's because I took out a
> layer that seemed to set the GetCaps over the edge. I'll put together a
> barebones .map and pass around that will hopefully be able to reproduce the
> problem.
> Many thanks, fellas!
> Charlton
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
