Not able to navigate through reference map {Scanned}
{Scanned} {Scanned}
SATish In Athens +30 6947758275
satsuman at GMAIL.COM
Wed Jul 11 08:22:36 EDT 2007
Well.. I have REFERENCE block in map file..
my box and marker are working.
but this tag is not working..
When i put this tag, reference as well as main image disappear..
Thanx
Satish
On 7/11/07, Siki Zoltan <siki at agt.bme.hu> wrote:
> Hi,
> Your solution use a static image, not clickable.
> Change your reference image from this
> > <img name="reference" src="graphics/reference.gif" height="120"
> > width="120" border="1">
> to this
> <input type="image" name="reference" src="[ref]" height="120"
> Meanwhile you should insert REFERENCE block into your map file, e.g.
> REFERENCE
> IMAGE graphics/reference.gif
> EXTENT ??? ??? ??? ???
> SIZE 120 120
> STATUS ON
> ... # see the map file reference
> END
> I send the mail to the list to, it can help someone else.
> Bye,
> Zoltan
> On Wed, 11 Jul 2007, SATish In Athens +30 6947758275 wrote:
> > Thanks a lot..
> > but yes, i have tried with putting in a form.. when I attached "input"
> tag
> > with it, got an error..
> > Well, my reference tag is like below, please have a look of it
> > <li class="last" >
> > <!--this is the holding spot (the anchor) for the reference
> > map-->
> > <DIV id="reference_anchor" align="center" style="position:relative;
> > visibility:visible; width:100%; height:100%;left:0px;
> > top:5px;left:-18;margin-bottom:0;">
> > <img src="graphics/white_pixel.gif" height="120" width="120"></DIV>
> > <!-- absolutely positioned layer to hold the reference map-->
> > <DIV id="reference" style="position:absolute; visibility:visible;
> > width:100%; height:100%; clip:rect(100%,100%,100%,100%);
> > background:transparent;">
> > width="120" border="1"></DIV>
> > </li>
> > So, i m not sure how to use input tag in it..
> > regards..
> > Satish
> >> Hi,
> >> Did you put the reference map into a input field of your form?
> >> Like:
> >> <input name="ref" type="image" src=[ref]>
> >> Bye
> >> Zoltan
> >> > Hey all..
> >> > I am trying to create my own map and it is working correct but when I
> >> click
> >> > on the reference map then instead of navigating to the right place in
> >> main
> >> > map , the map looses the focus..
> >> > And, after that map is required to be reloaded again..
> >> > So, this is something missing in map file or in HTML of the page ?
> >> > Any response will be highly appreciated..
> >> > Thank you
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070711/e9e1b09e/attachment.html
