Not able to navigate through reference map {Scanned}
{Scanned} {Scanned} {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Wed Jul 11 11:56:11 EDT 2007
Did you check web server log file when the main image diappears?
There should be there some error messages ...
Zoltan
On Wed, 11 Jul 2007, SATish In Athens +30 6947758275 wrote:
> Well.. I have REFERENCE block in map file..
> my box and marker are working.
> but this tag is not working..
> When i put this tag, reference as well as main image disappear..
> Thanx
> Satish
> On 7/11/07, Siki Zoltan <siki at agt.bme.hu> wrote:
>> Hi,
>> Your solution use a static image, not clickable.
>> Change your reference image from this
>> > <img name="reference" src="graphics/reference.gif" height="120"
>> > width="120" border="1">
>> to this
>> <input type="image" name="reference" src="[ref]" height="120"
>> Meanwhile you should insert REFERENCE block into your map file, e.g.
>> REFERENCE
>> IMAGE graphics/reference.gif
>> EXTENT ??? ??? ??? ???
>> SIZE 120 120
>> STATUS ON
>> ... # see the map file reference
>> END
>> I send the mail to the list to, it can help someone else.
>> Bye,
>> Zoltan
>> > Thanks a lot..
>> > but yes, i have tried with putting in a form.. when I attached "input"
>> tag
>> > with it, got an error..
>> > Well, my reference tag is like below, please have a look of it
>> > <li class="last" >
>> > <!--this is the holding spot (the anchor) for the reference
>> > map-->
>> > <DIV id="reference_anchor" align="center" style="position:relative;
>> > visibility:visible; width:100%; height:100%;left:0px;
>> > top:5px;left:-18;margin-bottom:0;">
>> > <img src="graphics/white_pixel.gif" height="120" width="120"></DIV>
>> > <!-- absolutely positioned layer to hold the reference map-->
>> > <DIV id="reference" style="position:absolute; visibility:visible;
>> > width:100%; height:100%; clip:rect(100%,100%,100%,100%);
>> > background:transparent;">
>> > width="120" border="1"></DIV>
>> > </li>
>> > So, i m not sure how to use input tag in it..
>> > regards..
>> > Satish
>> >> Hi,
>> >> Did you put the reference map into a input field of your form?
>> >> Like:
>> >> <input name="ref" type="image" src=[ref]>
>> >> Bye
>> >> Zoltan
>> >> > Hey all..
>> >> > I am trying to create my own map and it is working correct but when I
>> >> click
>> >> > on the reference map then instead of navigating to the right place in
>> >> main
>> >> > map , the map looses the focus..
>> >> > And, after that map is required to be reloaded again..
>> >> > So, this is something missing in map file or in HTML of the page ?
>> >> > Any response will be highly appreciated..
>> >> > Thank you
