C# mapserver
Tamas Szekeres szekerest at GMAIL.COM
Fri Jul 13 11:51:14 EDT 2007
I'm afraid I couldn't understand the problem exactly.
However I would suggest you to copy all of the dll-s (the mapscript
dll-s and all of the dependencies) into your application directory.
I suppose apache and IIS are listening on the same port (probably on
TCP 80) so you might want to configure any of them into a different
port, either by:
- Changing 'Listen 80' in httpd.conf or
- Changing the TCP Port setting on the default web side using the
Internet Information Services snap-in.
Best regards
Tamas
2007/7/13, lakku <veeraswamyd at yahoo.co.in>:
> hi
> iam woking with ms4w2.24
> in php it is working
> now iam working with mapscript Csharp
> if i have to run the project in c# ,i have to stop the apache service then
> only it is running and it is
> displaying error as "unable to load mapscipt_csharp.dll".
> if i  start the apache service then i have to stop the default website in
> IIS then csharp project is not
> running.
> plz solve my problem
> View this message in context: http://www.nabble.com/C--mapserver-tf4072921.html#a11575284
> Sent from the Mapserver - User mailing list archive at Nabble.com.
