Help with TIFFTAGs resolutions
Frank Warmerdam warmerdam at POBOX.COM
Fri Jul 13 11:37:05 EDT 2007
Gambin Dejan wrote:
> I have just one question and that will be all: regarding the screen
> resolution - which are the parameters that impact the screen resolution
> of my map? If I shiw those images in DWG viewer they are very "sharp"
> and look much better than shown on the map, with nearly the same display
> dimensions....
> Is there a way of modifying it?
Dejan,
MapServer uses full resolution imagery when you are zoomed in to full
resolution.
Perhaps the DWG viewer uses sub-pixel interpolation when you are zoomed
in past full resolution.  MapServer does not, by default, so things
will start to pixelate at that leve.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
