tcp
Stephen Kelly
steve at SJK.NET.AU
Mon Jul 16 07:57:04 EDT 2007
If you are getting a page not found error, that message has to come from a
WWW server, so it is finding the server, just not either the correct server
or the page on the server, so it is probably having a problem finding the
default document,
Try stopping IIS,
Reinstall the standard MS4W and see if that works
Good Luck
Stephen Kelly
Peepel
www.Peepel.com <http://www.peepel.com/>
_____
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Rodrigo Martín LÓPEZ GREGORIO
Sent: Monday, 16 July 2007 9:37 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] tcp
Hi Iakku.
- Do you have restarted the apache service? You can do this directly from
the apache-restart.bat located on ms4w folder or from "Services" on
"Administrative Tools" on Windows Control Panel (I'm guessing the english
names of the icons cause my windows is in spanish).
- When you access to the page, do you put the 8080 port in the url? like:
http://localhost:8080/mypage.php
- Isn't there any other service running on port 8080?
sorry if I ask some dumb questions.
Rodrigo.
On 7/16/07, lakku <veeraswamyd at yahoo.co.in> wrote:
hi
iam working with ms4w 2.2.4
iis and apache are using port 80
so simultaniously iis and apache are not ruuning
so i have changed port value in C:\ms4w\Apache\conf\httpd.conf file consists
LISTEN 80 and i have changed it as LISTEN 8080,but it is not working when i
runned the application it is displaying as "page not found"
but i haved changed the LISTEN 80 to LISTEN 8080 in ms4w2.1 there it is
working
plz tell me this
View this message in context:
http://www.nabble.com/tcp-tf4085692.html#a11612493
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070716/85acb82b/attachment.html
