Using PHP Shared Object Library with PHP/Mapscript,
MapServer and PostGIS
Bill Thoen
bthoen at GISNET.COM
Mon Jul 16 10:50:14 EDT 2007
I would like to try out PHP/Mapscript, but the data source for my
MapServer includes PostGIS files, and the installed version of PHP was
not compiled using the --with-pgsql switch. Rather than go through the
hassle of recompiling PHP, I noticed that you can use the dl() function
in PHP to load the necessary library. Specifically, I need the database
access functions pg_connect() and friends, and I'm using a Fedora Core 5
box.
My question is, where would I find the correct shared object library to
use with dl() or is this not the right approach?
TIA,
- Bill Thoen
GISnet - www.gisnet.com
303-786-9961
