PROCESSING "LUT=.... issue
A.Th.C. Hulst
hulst at ARGOSS.NL
Fri Jul 20 10:23:14 EDT 2007
Frank,
I have a fix (ugly, but it works):
in mapdrawgdal.c
--------------ParseDefaultLUT()------------
int user_defined=FALSE;
while( !all_done )
int this_in, this_out;
int lut_i;
while( isspace(*lut_read) )
lut_read++;
/* if we are at end, assum 255:255 */
if( *lut_read == '\0')
all_done = TRUE;
if ( !user_defined ){
// Only assume 255:255 end when user did not specify PROCESSING option
this_in = 255;
this_out = 255;
/* otherwise read "in:out", and skip past */
else
user_defined = TRUE;
the rest of the code
