PROCESSING "LUT=.... issue
Frank Warmerdam
warmerdam at POBOX.COM
Fri Jul 20 11:34:01 EDT 2007
A.Th.C. Hulst wrote:
> Frank,
> I have a fix (ugly, but it works):
> in mapdrawgdal.c
> --------------ParseDefaultLUT()------------
> int user_defined=FALSE;
> while( !all_done )
> int this_in, this_out;
> int lut_i;
> while( isspace(*lut_read) )
> lut_read++;
> /* if we are at end, assum 255:255 */
> if( *lut_read == '\0')
> all_done = TRUE;
> if ( !user_defined ){
> // Only assume 255:255 end when user did not specify PROCESSING option
> this_in = 255;
> this_out = 255;
> /* otherwise read "in:out", and skip past */
> else
> user_defined = TRUE;
> the rest of the code
Sander,
It seems that this code change just ignores the implicit
255:255 if there is any user provided lut points at all.
I'm not sure that this is advisable.
I'd suggest you file a specific bug against MapServer indicating
what you consider is the issue, and your proposed solution. But
I think that the above code won't quite do as is, unless I am
misunderstanding it.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
