MapServer 5.0.0 release plan ... and release of beta1
Daniel Morissette
dmorissette at MAPGEARS.COM
Thu Jul 26 10:03:56 EDT 2007
Ben Tuttle wrote:
> Does MS RFC 24 address bug #1975? Sounds like it, but I wanted to check.
I presume you are referring to comment #15 in that ticket?
http://trac.osgeo.org/mapserver/ticket/1975#comment:15
RFC-24 may fix it, but I don't think PHP MapScript suffered of the same
memory management issues as the other SWIG-based MapScript because it
didn't allow the creation of standalone objects the same way as SWIG
Mapscript did, so I doubt RFC-24 will have helped there.
Note that as I wrote in comment 16 of that ticket, intermittent crashes
are unlikely to be directly related to the main issue in that ticket
which is the fact that loadParams() doesn't work properly in a PHP
environment ... so a separate ticket would be required for the
intermittent crashes with a testcase to reproduce if you find that it
still happens with 5.0-beta1.
Daniel
Daniel Morissette
http://www.mapgears.com/
