generateSLD returns an empty SLD
Gilles Bassière
gilles.bassiere at MAKINA-CORPUS.COM
Thu Jul 26 10:10:52 EDT 2007
Hi list
I try to use the generateSLD method but can't get it to work.
I have the following code (adapted from Mapserver how-to) :
<?php
// define variables
define("MAPFILE", "/home/gba/public_html/and/test.map");
define("MODULE", "php_mapscript.so");
// load the mapscript module
if (!extension_loaded("MapScript")) dl(MODULE);
// open map
$oMap = ms_newMapObj(MAPFILE);
foreach ( $oMap->getAllLayerNames() as $layerName )
$oLayer = $oMap->getLayerByName($layerName);
// generate the sld for that layer
$SLD = $oLayer->generateSLD() ;
// return SLD to client
echo $SLD ;
I have several layers which are very simple and all look like this one :
# LAYER golf -------------------------------------
LAYER
NAME "golf"
GROUP "background"
CONNECTIONTYPE postgis
CONNECTION "host=localhost dbname=test user=test
password=xxx port=5432"
DATA "wkb_geometry FROM golf"
STATUS off
TYPE polygon
CLASS
NAME "Golf courses"
STYLE
COLOR 203 216 195
ANTIALIAS true
END
END
PROJECTION
"init=epsg:4326"
END
METADATA
"wms_title" "Golf courses"
"wms_srs" "EPSG:4326"
"wms_extent" "3.3 50.75 7.25 53.6"
END
END
The PHP script above returns the following output :
<StyledLayerDescriptor version="1.0.0"
xmlns="http://www.opengis.net/sld"
xmlns:gml="http://www.opengis.net/gml"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
</StyledLayerDescriptor>
This output is a valid SLD, I agree... But I expected to find the
parameters set up in the CLASS element, how should I proceed ? What is
going wrong there ?
Gilles Bassiere
MAKINA CORPUS
30 rue des Jeuneurs
FR-75011 PARIS
http://www.makina-corpus.com
