generateSLD returns an empty SLD
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu Jul 26 11:22:37 EDT 2007
Is it possible that the layers status is OFF (seems like that looking at
the layer definition)? It should be set to ON or DEFAULT
Later,
Gilles Bassière wrote:
> Hi list
> I try to use the generateSLD method but can't get it to work.
> I have the following code (adapted from Mapserver how-to) :
> <?php
> // define variables
> define("MAPFILE", "/home/gba/public_html/and/test.map");
> define("MODULE", "php_mapscript.so");
> // load the mapscript module
> if (!extension_loaded("MapScript")) dl(MODULE);
> // open map
> $oMap = ms_newMapObj(MAPFILE);
> foreach ( $oMap->getAllLayerNames() as $layerName )
> $oLayer = $oMap->getLayerByName($layerName);
> // generate the sld for that layer
> $SLD = $oLayer->generateSLD() ;
> // return SLD to client
> echo $SLD ;
> I have several layers which are very simple and all look like this one :
> # LAYER golf -------------------------------------
> LAYER
> NAME "golf"
> GROUP "background"
> CONNECTIONTYPE postgis
> CONNECTION "host=localhost dbname=test user=test password=xxx
> port=5432"
> DATA "wkb_geometry FROM golf"
> STATUS off
> TYPE polygon
> CLASS
> NAME "Golf courses"
> STYLE
> COLOR 203 216 195
> ANTIALIAS true
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> "wms_title" "Golf courses"
> "wms_srs" "EPSG:4326"
> "wms_extent" "3.3 50.75 7.25 53.6"
> END
> END
> The PHP script above returns the following output :
> <StyledLayerDescriptor version="1.0.0"
> xmlns="http://www.opengis.net/sld"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/sld
> http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
> </StyledLayerDescriptor>
> This output is a valid SLD, I agree... But I expected to find the
> parameters set up in the CLASS element, how should I proceed ? What is
> going wrong there ?
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
