How to Fix Ratty Line Rendering in WMS? - Redux
Bill Thoen
bthoen at GISNET.COM
Fri Jul 27 14:00:16 EDT 2007
I hadn't done that, but when I did, I got an error printed on the map:
"Invalid SRS given. SRS must be valid for all requested layers"
I also have EPSG:2163 listed as one of the option in the WEB METADATA of
my WMS MAP file. Do I need to add it somewhere in my WMS layers
definitions too?
Daniel Morissette wrote:
> Bill Thoen wrote:
>> I've now posted some images showing the problem at
>> http://www.gisnet.com/wms_examples/.
>> To summarize the problem, I've set up a MapServer WMS Server that's
>> got road data in native MapInfo format with a coordinate system based
>> on Lat/Long (EPSG:4269). When I display it in a MapServer client map
>> using the same projection EPSG:4269, the line work looks nice and
>> clean. However, if I try to use a different projection in my client
>> like EPSG:2163 (Lambert), the lines are pretty shabby looking.
> Did you list EPSG:2163 in the wms_srs metadata of the CONNECTIONTYPE
> WMS layer in you client mapfile?
> The "wms_srs" metadata in a client WMS connection layer definition is
> used to list all the projections (SRS) supported by the remote server.
> It's a space-separated list, e.g.
> LAYER
> METADATA
> "wms_srs" "EPSGL4326 EPSG:4269 EPSG:2163"
> END
> END
> If the requested SRS is not found in this list then MapServer
> concludes that the remote server doesn't support that projection and
> then it uses the layer's default SRS for its GetMap call to the remote
> server and then reprojects the resulting image on the fly.
> This is probably what's happening here and explains the shabby looking
> lines.
> Daniel
