How to Fix Ratty Line Rendering in WMS? - Redux
Daniel Morissette dmorissette at MAPGEARS.COM
Fri Jul 27 13:37:41 EDT 2007
Bill Thoen wrote:
> I've now posted some images showing the problem at
> http://www.gisnet.com/wms_examples/.
> To summarize the problem, I've set up a MapServer WMS Server that's got
> road data in native MapInfo format with a coordinate system based on
> Lat/Long (EPSG:4269). When I display it in a MapServer client map using
> the same projection EPSG:4269, the line work looks nice and clean.
> However, if I try to use a different projection in my client like
> EPSG:2163 (Lambert), the lines are pretty shabby looking.
Did you list EPSG:2163 in the wms_srs metadata of the CONNECTIONTYPE WMS
layer in you client mapfile?
The "wms_srs" metadata in a client WMS connection layer definition is
used to list all the projections (SRS) supported by the remote server.
It's a space-separated list, e.g.
LAYER
   METADATA
     "wms_srs" "EPSGL4326 EPSG:4269 EPSG:2163"
   END
END
If the requested SRS is not found in this list then MapServer concludes
that the remote server doesn't support that projection and then it uses
the layer's default SRS for its GetMap call to the remote server and
then reprojects the resulting image on the fly.
This is probably what's happening here and explains the shabby looking
lines.
Daniel
Daniel Morissette
http://www.mapgears.com/
