linked tables and spatial queries
Micha Silver
micha at ARAVA.CO.IL
Tue Jul 31 10:04:41 EDT 2007
Dylan Beaudette wrote:
> On Sunday 29 July 2007 06:23, you wrote:
>> On Thu, 28 Jun 2007 18:50:47 -0700, Dylan Beaudette
>> <dylan.beaudette at GMAIL.COM> wrote:
>>> I was in need of this type of functionality, and found it through two
>>> methods:
>>> 1. define a query template in your mapfile, and have it redirect the user
>>> to a PHP page which can do related DB lookups and presentation. You can
>>> pass along mapserver query results on the URL.
>>> 2. use something like ka-map and adjust how the query system displays the
>>> results in the left-hand side panel. I modified the query functions such
>>> that all searching and presentation was done via postgres+PHP.
>>> let me know if you need the details.
>> Hi Dylan:
> Hi! Glad to hear that you have made some progress.
>> I'm working on a new site (displaying water quality for farmers around our
...{clipped]...
>> When I use the query button in the ka-map interface, what I get back (in
>> the left panel) is :
>> Layer Name:
>> Wells
>> results: 1
> Right -- I had the same thing happen... details below.
>> So it looks like the querying is working in general, just not retrieving
>> the columns of data. Can you give me any pointers? I'd be glad to try to
>> rewrite the map_query.php stuff in ka-map if necessary, but what should
>> that script do exactly? The option to just write a query template in php is
>> tempting but ka-map seems to be ignoring that TEMPLATE file.
> Since I am using the kaExplorer interface, the files you might be interested
> in are in the folder tools/kaExplorer, specifically startUp.js . However, the
> query system uses the file map_query_float.php
> I made my own version of this file, essentially removing much of what kamap
> does by default :
> right after the lines:
> //print common header to the floating query results box:
> // echo "<b>Query Results:</b><br>";
> ... put your stuff here. spatial queries (or attribute) are simple to write in
> postgis- so I just made some functions which query tables based on either a
> coordinate pair -- which this PHP function has access to ($coords) -- or a
> bounding box, pass them to postgis, and return an associative array as the
> result. loop through the result printing an HTML table -- there is an example
> in the code -- and there you have it!
> Good luck,
> Dylan
Thanks for the reply. That's what I was looking for.
BTW, after some more fiddling, here's what I've found regarding
ka-map's built in querying system:
1- You must enter "queryable" "true" (obviously) in the METADATA section
of each LAYER that you want to query. This point is mentioned in the
ka-map wiki : http://ka-map.ominiverdi.org/wiki/index.php/Query
2- You must have all queryable layers in their own GROUP. This I learned
from your post:
http://lists.maptools.org/pipermail/ka-map-users/2006-October/002298.html
3- I got query results ONLY when I added a "fields" line in the METADATA
section as so:
"fields" "name:Name,drill_dept:Depth,elevation:Elevation,aquifer_na:Aquifer"
It's in the format: "fields" "column_1:alias_1,column_2:alias_2"
Then the aliases happily appear in ka-map's left hand result window,
with data values underneath.
And one additional important piece of information that I gleaned from an
obscure post somewhere: My DATA points to a view in postgresql. The view
is a join of the geom table and the data table. (I'd assume many people
work this way.) In order for the query to work when pointing to a
postgresql view, you MUST have a column in the view named 'oid' with
unique values. AND the view should be entered into the geometry_columns
table in postgis.
It took me a while to collect all these bits and pieces, so I'm trying
to post this to mapserver-users also. My first question never made it to
the list; hope this gets thru to possibly aid others.
Warm regards,
Micha
Micha Silver
Arava Development Co
+972-8-6592270
