mapscript in TOMCAT
Victor Herrero Cazurro
la_barrenadora at HOTMAIL.COM
Tue Jun 12 06:12:52 EDT 2007
Ok, but what path??? because this class it works correctly in stand alone
application. Then the path of SO is correctly, or not? I think, that the
problem is in path of TOMCAT. It is as if TOMCAT did not take the same path
that the SO.
thanks in advance,
>From: Umberto Nicoletti <umberto.nicoletti at GMAIL.COM>
>Reply-To: Umberto Nicoletti <umberto.nicoletti at GMAIL.COM>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] mapscript in TOMCAT
>Date: Tue, 12 Jun 2007 11:58:49 +0200
>mapscript.dll depends on other dlls that are not found in that path.
>Use a tool like dependency walker to find out dependencies and add
>them to the path.
>Umberto
>On 6/12/07, Victor Herrero Cazurro <la_barrenadora at hotmail.com> wrote:
>>Good morning!!
>>I have a web application, the method who call mapscript class, it works
>>correctly in stand alone application, but when run in TOMCAT, throw a
>>exception:
>>"GRAVE: Servlet.service() para servlet action lanzó excepción
>>java.lang.UnsatisfiedLinkError: no mapscript in java.library.path
>> at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1682)
>> at java.lang.Runtime.loadLibrary0(Runtime.java:822)
>> at java.lang.System.loadLibrary(System.java:993)
>> at
>>edu.umn.gis.mapscript.mapscriptJNI.<clinit>(mapscriptJNI.java:23)
>> at edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:276)
>> at es.nomenclator.struts.model.WFS.getfeature(WFS.java:24)"
>>The line that reference is:
>>"mapObj map = new
>>mapObj("C:\\ms4w\\Apache\\htdocs\\mapserver\\app\\app.map");"
>>I have a environment variable:
>>"path = C:\ms4w\Apache\cgi-bin;C:\ms4w\Apache\cgi-bin\mapscript\java"
>>in this path are "mapscript.dll" and "mapscript.jar"
>>And "mapscript.jar" is in classpath to web application.
>>Can somebody tell me what happend??
>>Thanks
>>_________________________________________________________________
>>¿Estás pensando en cambiar de coche? Todas los modelos de serie y extras
>>en
>>MSN Motor. http://motor.msn.es/researchcentre/
Descubre la descarga digital con MSN Music. Más de un millón de canciones.
http://music.msn.es/
