mapscript in TOMCAT
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Tue Jun 12 06:25:02 EDT 2007
This path you wrote in the first email:
"path = C:\ms4w\Apache\cgi-bin;C:\ms4w\Apache\cgi-bin\mapscript\java"
should probably be:
PATH = C:\ms4w\Apache\cgi-bin;C:\ms4w\Apache\cgi-bin\mapscript\java;%PATH%
The latter preserves previous path settings, while the former resets
the path completely, which is probably not what you intended to do.
HTH,
Umberto
On 6/12/07, Victor Herrero Cazurro <la_barrenadora at hotmail.com> wrote:
> Ok, but what path??? because this class it works correctly in stand alone
> application. Then the path of SO is correctly, or not? I think, that the
> problem is in path of TOMCAT. It is as if TOMCAT did not take the same path
> that the SO.
> thanks in advance,
> >From: Umberto Nicoletti <umberto.nicoletti at GMAIL.COM>
> >Reply-To: Umberto Nicoletti <umberto.nicoletti at GMAIL.COM>
> >To: MAPSERVER-USERS at LISTS.UMN.EDU
> >Subject: Re: [UMN_MAPSERVER-USERS] mapscript in TOMCAT
> >Date: Tue, 12 Jun 2007 11:58:49 +0200
> >mapscript.dll depends on other dlls that are not found in that path.
> >Use a tool like dependency walker to find out dependencies and add
> >them to the path.
> >Umberto
> >>Good morning!!
> >>I have a web application, the method who call mapscript class, it works
> >>correctly in stand alone application, but when run in TOMCAT, throw a
> >>exception:
> >>"GRAVE: Servlet.service() para servlet action lanzó excepción
> >>java.lang.UnsatisfiedLinkError: no mapscript in java.library.path
> >>         at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1682)
> >>         at java.lang.Runtime.loadLibrary0(Runtime.java:822)
> >>         at java.lang.System.loadLibrary(System.java:993)
> >>         at
> >>edu.umn.gis.mapscript.mapscriptJNI.<clinit>(mapscriptJNI.java:23)
> >>         at edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:276)
> >>         at es.nomenclator.struts.model.WFS.getfeature(WFS.java:24)"
> >>The line that reference is:
> >>"mapObj map = new
> >>mapObj("C:\\ms4w\\Apache\\htdocs\\mapserver\\app\\app.map");"
> >>I have a environment variable:
> >>in this path are "mapscript.dll" and "mapscript.jar"
> >>And "mapscript.jar" is in classpath to web application.
> >>Can somebody tell me what happend??
> >>Thanks
> >>_________________________________________________________________
> >>¿Estás pensando en cambiar de coche? Todas los modelos de serie y extras
> >>en
> >>MSN Motor. http://motor.msn.es/researchcentre/
> Descubre la descarga digital con MSN Music. Más de un millón de canciones.
> http://music.msn.es/
