mapserver segfaults on x68_64 intel xeon
Tamas Szekeres szekerest at GMAIL.COM
Fri Mar 2 18:52:40 EST 2007
I have already fixed this problem for the CVS HEAD.
"Revision 1.103  2006/10/22 17:48:24  tamas
Changed OGRLayerGetAutoStyle not to pass NULL pointer to
GetRGBFromString causing access violation."
However it have not been backported to 4.10 yet.
Tamas
2007/3/2, Alessandro Pasotti <ale.pas at tiscali.it>:
> Il 16:46, venerdì 2 marzo 2007, Umberto Nicoletti ha scritto:
> > Did you reconfigure with --enable-debug?
> > After that run shp2img in gdb (or xxgdb if it still exists) and put a
> > breakpoint in msOGRLayerGetAutoStyle. Then proceed with the step
> > instruction until it crashes. You should be able to inspect the local
> > variables and see what values were passed to GetRGBFromString.
> Ok, I've found the problem:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1950
> I applied this patch and now it works, any chance it will be fixed in future
> releases?
> linux:~/webgis # diff mapogr.cpp mapserver-4.10.1/mapogr.cpp
> 2318a2319,2326
> >               // ABP: patch
> >               const char *pszColor;
> >                  pszColor = poBrushStyle->BackColor(bIsNull);
> >                   if (!bIsNull &&
> poBrushStyle->GetRGBFromString(pszColor,r,g,b,t))
> >                       MS_INIT_COLOR(c->styles[0].backgroundcolor, r, g, b);
> 2324a2333
> Still remains a mistery to me why it works without patches on my local
> machine.
> Thanks Umberto for pointing me in the right direction.
> Alessandro Pasotti
> itOpen - "Open Solutions for the Net Age"
> w3:  www.itopen.it
> Linux User# 167502
