wms.jpl.nasa.gov renders on LINUX but not in the MS4W install
    Andrew Parker
    aparker1969 at YAHOO.COM
    Sat Mar  3 08:27:21 PST 2007
Bart:
the Windows machine is running Mapserver 4.10.0
The Linux machine is running Mapserver 4.8.3
Anyway, Jeff posted a response that worked.  I changed 'styles' to 'style'.  Then I seperated the two layers.
Thanks for the feedback.
Andrew
----- Original Message ----
From: Bart van den Eijnden (OSGIS) <bartvde at osgis.nl>
To: Andrew Parker <aparker1969 at YAHOO.COM>
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Friday, March 2, 2007 1:01:14 PM
Subject: Re: [UMN_MAPSERVER-USERS] wms.jpl.nasa.gov renders on LINUX but not in the MS4W install
Do the Linux and Windows environments have the same version of
Mapscript/Mapserver? Or is there a version difference?
It could be related to this:
http://lists.umn.edu/cgi-bin/wa?A2=ind0610&L=MAPSERVER-USERS&P=R32308
so maybe you can try:
CONNECTION "http://wms.jpl.nasa.gov/wms.cgi?styles=&";;
Best regards,
Bart
Andrew Parker schreef:
> I am trying to add the modis and global_mosaic layers from
> http://wms.jpl.nasa.gov to the map in my MS4W install (on Windows XP and
> Windows Server2003).  WMS layers render from terraservice.net with no
> problems.  The code in the mapfile works with the LINUX test box.
> Does anyone have a reason or solution?  Be easy on me as I am new to
> Mapserver.  Below is my mapfile code.
> Thanks in advances for any help.
> Andrew.
> # Start of map file
> # Sample map file for a chameleon app.
> NAME DEMO
> STATUS ON
> SIZE 400 300
> SYMBOLSET ../etc/symbols.sym
> EXTENT -109.1 31.26 -102.89 37.09
> UNITS DD
> PROJECTION
>   "init=epsg:4326"
> END
> SHAPEPATH "../data"
> IMAGECOLOR 25 25 112
> FONTSET ../etc/fonts.txt
> TRANSPARENT FALSE
> # IMAGETYPE - set to PNG24 in /congif/chameleon.xml
> # Start of web interface definition
> WEB
>   #MINSCALE 2000000
>   #MAXSCALE 50000000
> # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
> # of the drive where the .MAP file resides.
>   IMAGEPATH "/ms4w/tmp/ms_tmp/"
>   IMAGEURL "/ms_tmp/"
> #  LOG "/tmp/gmap.log"
>   METADATA
>   END
> END
> # Start of reference map
> REFERENCE
>    IMAGE images/ref_msone.jpg
>    EXTENT -126.12 23.27 -66.14 50.15
>    STATUS ON
>   COLOR -1 -1 -1
>   OUTLINECOLOR 255 0 0
>   SIZE 120 90
> END
> # Start of legend
> LEGEND
>   KEYSIZE 18 12
>   LABEL
>     TYPE BITMAP
>     SIZE MEDIUM
>     COLOR 0 0 89
>   END
>   STATUS ON
> END
> # Start of scalebar
> SCALEBAR
>   IMAGECOLOR 255 255 255
>   LABEL
>     COLOR 0 0 0
>     SIZE SMALL
>   END
>   SIZE 150 5
>   COLOR 255 255 255
>   BACKGROUNDCOLOR 0 0 0
>   OUTLINECOLOR 0 0 0
>   UNITS Miles
>   INTERVALS 5
>   STATUS ON
> END
> QUERYMAP
>   STYLE HILITE
>   COLOR 255 0 0
> END
> # Symbol for drawing fat lines
> SYMBOL
>      NAME "BigLine"
>      TYPE ELLIPSE
>      POINTS 1 1 END
> END
> # Symbol for drawing dashed lines
> SYMBOL
>      NAME "DashedLine"
>      TYPE ELLIPSE
>      POINTS 1 1 END
>      STYLE 10 10 END
> END
> # Symbol for drawing spots
> SYMBOL
>      NAME "Circle"
>      FILLED true
>      TYPE ellipse
>      POINTS 1 1 END
> END
> # Country layer
> LAYER
>     NAME "Countries"
>     STATUS on
>     TYPE polygon
>     DATA "countries"
>     UNITS dd
>     PROJECTION
>       "init=epsg:4326"
>     END
>    CLASS
>         # A template defined at the class level is used to
>         # display the results for each reponse to a query. If a
>         # query results in N hits, then the template will be used
>         # N times. To be queriable a layer must specify a CLASS
>         # level template.
>         TEMPLATE "/ms4w/apps/msone/htdocs/msone_countries_query.html"
>         NAME "USA"
>         EXPRESSION ('[COUNTRY]' eq 'US')
>         STYLE
>            COLOR 238 232 170
>         END
>     END # end class
>     CLASS
>         # level template.
>         NAME "OTHER"
>         EXPRESSION ('[COUNTRY]' ne 'US')
>         STYLE
>            COLOR 205 190 112
>         END
>     END # end class
> END # end layer
> # Line layer for Country boundaries
> LAYER
>     UNITS dd
>     PROJECTION
>       "init=epsg:4326"
>     END
>     NAME "Boundaries"
>     STATUS on
>     TYPE line
>     DATA "countries"
>     CLASS
>         STYLE
>             COLOR 0 0 0
>         END
>     END # end class
> END # end layer
> #  USGS_topo
> LAYER
>   NAME "Terraserver_DRG"
>   STATUS off
>   TYPE RASTER
>   CONNECTIONTYPE WMS
>   CONNECTION "http://terraservice.net/OgcMap.ashx?";;
>   METADATA
>     "wms_srs"    "EPSG:4326"
>     "wms_title"    "Digital Raster Graphic"
>     "wms_name"    "DRG"
>     "wms_server_version"    "1.1.1"
>     "wms_format"    "image/jpeg"
>     "wms_layers"    "drg"
>     "wms_group_title" "background"
>   END
>   PROJECTION
>     "init=epsg:4326"
>   END
> END
> # ********************  Orthophoto ********************
> LAYER
>   NAME "TerraServer_Orthophoto"
>   STATUS off
>   TYPE RASTER
>   CONNECTIONTYPE WMS
>   METADATA
>     "wms_title"    "Orthophoto"
>     "wms_name"    "DOQ"
>     "wms_layers"    "drg"
>   END
>   PROJECTION
>     "init=epsg:4326"
>   END
> END
> # ******************** Nexrad Radar ********************
> LAYER
>   NAME Nexrad_RADAR
>   STATUS OFF
>   GROUP "Background"
>   TYPE RASTER
>   CONNECTIONTYPE WMS
>   CONNECTION "http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi?";;
>   PROJECTION
>     "init=epsg:4326"
>   END
>   METADATA
>     "wms_name" "nexrad-n0r-m45m"
>     "wms_style" ""
>     "wms_title" "NEXRAD"
>   END
> END
> # ******************** MODIS derived blue marble image ********************
> LAYER
>    NAME Blue_Marble
>    STATUS on
>    PROJECTION
>      "init=epsg:4326"
>    END
>    TYPE RASTER
>    OFFSITE 0 0 0
>    CONNECTIONTYPE WMS
>    CONNECTION "http://wms.jpl.nasa.gov/wms.cgi?";;
>    METADATA
>      "wms_name" "modis,global_mosaic"
>      "wms_styles" ""
>      "wms_title" "BlueMarble"
>    END
> END
> # State boundaries layer - polygon (for shading)
> LAYER
>      NAME "states_poly"
>      DATA "statesp020"
>      UNITS dd
>      PROJECTION
>       "init=epsg:4326"
>      END
>      STATUS off
>      TYPE polygon
>      LABELCACHE on
>      LABELITEM "STATE"
>      CLASS
>           STYLE
>                # COLOR 238 232 170
>           END
>      END
> END
> # State boundaries layer - line (for fat boundary)
> LAYER
>      NAME "states"
>      DATA "statesp020"
>      UNITS dd
>      PROJECTION
>       "init=epsg:4326"
>      END
>      STATUS off
>      TYPE line
>      LABELCACHE on
>      LABELITEM "STATE"
>      CLASS
>           NAME "State Line"
>           STYLE
>                SYMBOL "BigLine"
>                SIZE 2
>                COLOR 0 0 0
>           END
>      END
> END
> # Road layer - interstates only at large scale
> LAYER
>      NAME "interstate1"
>      GROUP "roads"
>      DATA "roadtrl020"
>      STATUS off
>      TYPE line
>      UNITS dd
>      PROJECTION
>       "init=epsg:4326"
>      END
>      LABELCACHE on
>      LABELITEM "NAME"
>      CLASSITEM "FEATURE"
>      MINSCALE 7500001
>      CLASS
>           NAME "Interstate Hwy"
>           EXPRESSION /Limited Access*/
>           STYLE
>                SYMBOL "BigLine"
>                SIZE 1
>                COLOR 0 0 0
>           END
>           LABEL
>                TYPE truetype
>                FONT "arial"
>                SIZE 8
>                OUTLINECOLOR 255 255 255
>                COLOR 0 0 0
>                MINDISTANCE 200
>                POSITION auto
>                ANGLE auto
>                MINFEATURESIZE 50
>           END
>      END
> END
> # ROC Sites
> LAYER
>     NAME "ROCsites"
>     STATUS off
>     UNITS dd
>     PROJECTION
>       "init=epsg:4326"
>     END
>     TYPE point
>     DATA "ROCsites"
>     MAXSCALE 1200000
>     LABELITEM "SITE_NAME"
>     CLASS
>         NAME "ROC Sites"
>           STYLE
>                SYMBOL "Circle"
>                SIZE 9
>                COLOR 255 127 0 #coral
>           END
>          LABEL
>             TYPE truetype   # use truetype font
>             FONT "arialbd"  # use arial bold
>             SIZE 7          # use 8 point size
>             COLOR 255 127 0   # color text coral
>             BACKGROUNDCOLOR 255 255 255 # render text on white bg
>             MINDISTANCE 50  # labels > 50 pixels apart
>             POSITION auto     # center labels below feature
>             ANTIALIAS true  # antialias the text
>         END # end label
>     END # end class
> END # end layer
> # ROC Monitoring Wells
> LAYER
>     NAME "ROCmw"
>     STATUS off
>     UNITS dd
>     TYPE point
>     DATA "ROCmw"
>     LABELITEM "Well_Name"        # labels use value in column "NAME"
>     LABELCACHE on
>     LABELMAXSCALE 1200000
>     MAXSCALE 1200000
>     CLASS
>         NAME "ROC MWs"
>           STYLE
>                SYMBOL "Circle"
>                SIZE 9
>                COLOR 0 0 205 #Medium Blue
>           END
>         LABEL
>             COLOR 0 0 205   # color text coral
>         END # end label
>     END # end class
> END # end layer
> END # Map File
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
____________________________________________________________________________________
Be a PS3 game guru.
Get your game face on with the latest PS3 news and previews at Yahoo! Games.
http://videogames.yahoo.com/platform?platform=120121
More information about the MapServer-users
