How do I not render the white background when displing NEXRAD
from a WMS
Brent Wood
pcreso at PCRESO.COM
Sat Mar 3 13:25:58 EST 2007
--- Andrew Parker <aparker1969 at YAHOO.COM> wrote:
> Ok. I give up. How do I NOT render the white background? I just want the
> base reflectivity to show. I am accessing a base reflectivity layer from a
> WMS located at:
> "http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi?"
See transparency & offsite options for the layer definition:
http://mapserver.gis.umn.edu/docs/reference/mapfile/layer
TRANSPARENCY 0
OFFSITE 255 255 255
I've only used it in my WMS server to provide layers with the white background
removed. I'm assuming it will work in a client as well. Also ensure you are not
using JPG images (I see you are using PNG24, but it is worth mentioning anyway
:-), as they don't support transparency & can finish up with off-white pixels
for white in the lossy compression.
Cheers,
Brent Wood
> My test site is available for viewing at:
> "http://mapserver.rthicksconsult.com"
> There are two test sites. 1) the form button "Click Here..."; my first map.
> 2) Link: Test1; my first Chamelon map.
> Both have the NexRad Layer as shown below in the partial mapfile.
> Thanks in advance.
> Andrew.
> # Start of map file
> # Sample map file for a chameleon app.
> NAME DEMO
> STATUS ON
> SIZE 400 300
> SYMBOLSET ../etc/symbols.sym
> EXTENT -109.1 31.26 -102.89 37.09
> UNITS DD
> PROJECTION
> "init=epsg:4326"
> END
> SHAPEPATH "../data"
> IMAGECOLOR 25 25 112
> FONTSET ../etc/fonts.txt
> TRANSPARENT TRUE
> # IMAGETYPE - set to PNG24 in /congif/chameleon.xml
> # ******************** NexRad********************
> LAYER
> NAME "Nexrad"
> STATUS ON
> TYPE RASTER
> CONNECTIONTYPE WMS
> CONNECTION "http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi?"
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> "wms_name" "nexrad-n0r"
> "wms_server_version" "1.1.1"
> "wms_srs" "EPSG:4326"
> "wms_format" "image/jpeg"
> "wms_title" "NEXRAD BASE REFLECT"
> END
> END
> END # end of mapfile
