mapserver with postgis problems
Sami Jan sami.jan at GMAIL.COM
Sun Mar 4 11:20:42 EST 2007
I have managed to narrow down the problem - mapServer does not plot
projected points - points in lat/long are rendered OK
The following block of data renders the points OK:
PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
    END
The following does not:
PROJECTION
    'proj=utm'
    'zone=15'
    'ellps=GRS80'
    'datum=NAD83'
    'units=m'
    'no_defs'
    END
It fails with this error:
msPOSTGISLayerFreeItemInfo called\r
msProjectRect(): all points failed to reproject, trying to fall back to
using world bounds ... hope this helps.\r
msPOSTGISLayerWhichShapes called\r
