Does MapServer support WMS time series using polygon shapefiles?
Pericles S. Nacionales naci0002 at UMN.EDU
Fri Mar 9 13:12:10 EST 2007
Peter,
What happens when you change the TYPE from RASTER to POLYGON?
-Perry
Peter Shrock wrote:
> Hello,all:
> I am having difficulties to make WMS time series work.
> I am using mapserver 4.10.0. I tested point data with time dimension, it
> worked. I tested tiled polygons, it worked.
> But I cannot get polygon shapefile work for time series WMS
> I used identitical polygon shapefiles, one shapefile for one year. tile index
> shapefile (index1.shp) was created using tile4ms.exe, and I verified the
> contents of the file.
> I tried two methods in order to make the WMS time series work. Both failed.
> Could you please help me?
> # Test method 1: everything in one layer object
> LAYER
>   NAME "timemap"
>   TYPE RASTER
>   STATUS ON
>   METADATA
>         "wms_title" "timemap"
>         "wms_timeformat" "YYYYMMDD"
>         "wms_timeextent" "20021130/20061130"
>         "wms_timeitem" "DATETIME"
>         "wms_timedefault" "20021130"
>         "wms_srs" "EPSG:4326"
>    END
>    TILEINDEX "index1.shp"
>    TILEITEM  "Location"
>     CLASSITEM "color_code"
>     CLASS
>     NAME  "TYPE 1"
>       EXPRESSION ([color_code]==1)
>       COLOR      220 120 130
>         OUTLINECOLOR 150 150 150
>     END
>     CLASS
>     NAME  "TYPE 2"
>       EXPRESSION ([color_code]==2)
>       COLOR      255 255 155
>     END
>     CLASS
>     NAME  "TYPE 3"
>       EXPRESSION ([color_code]==0)
>       COLOR      200 200 200
>         OUTLINECOLOR 100 100 100
>     END
> END # one layer object method
> # Test method 2: seperate tileindex layer and data layer
> LAYER
>     NAME "mylayer"
>     STATUS ON
>     TYPE RASTER
>     TILEINDEX "index1"
>     TILEITEM "Location"
>   PROJECTION
>     "init=epsg:4326"
>   END
>   METADATA
>     "wms_title" "mylayer"
>     "wms_srs"   "epsg:4326"
>     "wms_timedefault" "20030210"
>   END
>     SIZEUNITS PIXELS
>     CLASS
>     NAME  "TYPE 1"
>       COLOR      220 120 130
>     END
>     CLASS
>     NAME  "TYPE 2"
>       COLOR      255 255 155
>     END
>     CLASS
>     NAME  "TYPE 3"
>       COLOR      200 200 200
>     END
> END
> LAYER
>   NAME "tidx"
>   TYPE TILEINDEX
>   STATUS ON
>   DATA index1
>   FILTERITEM 'DATETIME'
>   FILTER '%DATETIME%'
> END # tile layer
> The error message is:
> msDrawMap(): Image handling error. Failed to draw layer named 'timemap'.
> msDrawRaster(): Image handling error. Unrecognized or unsupported image format
> drawEPP(): Image handling error. EPPL7 support is not available.
> The error message does not seem helpful.
> Thanks
> Peter
> ____________________________________________________________________________________
> Bored stiff? Loosen up...
> Download and play hundreds of games for free on Yahoo! Games.
> http://games.yahoo.com/games/front
