Does MapServer support WMS time series using polygon
shapefiles?
Peter Shrock
thesl at YAHOO.COM
Sun Mar 11 10:18:53 EDT 2007
When I changed the TYPE from RASTER to POLYGON using both methods, I got this
error:
msDrawMap(): Image handling error. Failed to draw layer named 'timemap'.
msDBFGetItemIndex(): DBASE file error. Item 'TIMES' not found
I guess this means MapServer tried to find TIMES field in the time series
shapefiles. But this field is only in the tile index shapefile.
This error message is consistant in two PCs I have tested.
However, to make things even more confusing, I tested on two PCs using TYPE
RASTER, and both methods. On the second PC, I actually got a blank image (with
the scale bar only), which means that MapServer does not think there is any
error. I removed the &TIME parameter, and still got a blank image (with the
scale bar only).
The value in the "Times" field of the tile polygon was added using ArcView, so
only YYYYMMDD date format is supported.
The mapserver cgi progrmas were from the ms4w package (I deleted all the files
starting with php* though).
By the way, which method I used is the correct/prefereed method?
Thanks
Peter
--- "Pericles S. Nacionales" <naci0002 at umn.edu> wrote:
> Peter,
> What happens when you change the TYPE from RASTER to POLYGON?
> -Perry
> Peter Shrock wrote:
> > Hello,all:
> > I am having difficulties to make WMS time series work.
> > I am using mapserver 4.10.0. I tested point data with time dimension, it
> > worked. I tested tiled polygons, it worked.
> > But I cannot get polygon shapefile work for time series WMS
> > I used identitical polygon shapefiles, one shapefile for one year. tile
> index
> > shapefile (index1.shp) was created using tile4ms.exe, and I verified the
> > contents of the file.
> > I tried two methods in order to make the WMS time series work. Both failed.
> > Could you please help me?
> > # Test method 1: everything in one layer object
> > LAYER
> > NAME "timemap"
> > TYPE RASTER
> > STATUS ON
> > METADATA
> > "wms_title" "timemap"
> > "wms_timeformat" "YYYYMMDD"
> > "wms_timeextent" "20021130/20061130"
> > "wms_timeitem" "DATETIME"
> > "wms_timedefault" "20021130"
> > "wms_srs" "EPSG:4326"
> > END
> > TILEINDEX "index1.shp"
> > TILEITEM "Location"
> > CLASSITEM "color_code"
> > CLASS
> > NAME "TYPE 1"
> > EXPRESSION ([color_code]==1)
> > COLOR 220 120 130
> > OUTLINECOLOR 150 150 150
> > END
> > CLASS
> > NAME "TYPE 2"
> > EXPRESSION ([color_code]==2)
> > COLOR 255 255 155
> > END
> > CLASS
> > NAME "TYPE 3"
> > EXPRESSION ([color_code]==0)
> > COLOR 200 200 200
> > OUTLINECOLOR 100 100 100
> > END
> > END # one layer object method
> > # Test method 2: seperate tileindex layer and data layer
> > LAYER
> > NAME "mylayer"
> > STATUS ON
> > TYPE RASTER
> > TILEINDEX "index1"
> > TILEITEM "Location"
> > PROJECTION
> > "init=epsg:4326"
> > END
> > METADATA
> > "wms_title" "mylayer"
> > "wms_srs" "epsg:4326"
> > "wms_timedefault" "20030210"
> > END
> > SIZEUNITS PIXELS
> > CLASS
> > NAME "TYPE 1"
> > COLOR 220 120 130
> > END
> > CLASS
> > NAME "TYPE 2"
> > COLOR 255 255 155
> > END
> > CLASS
> > NAME "TYPE 3"
> > COLOR 200 200 200
> > END
> > END
> > LAYER
> > NAME "tidx"
> > TYPE TILEINDEX
> > STATUS ON
> > DATA index1
> > FILTERITEM 'DATETIME'
> > FILTER '%DATETIME%'
> > END # tile layer
> > The error message is:
> > msDrawRaster(): Image handling error. Unrecognized or unsupported image
> format
> > drawEPP(): Image handling error. EPPL7 support is not available.
> > The error message does not seem helpful.
____________________________________________________________________________________
TV dinner still cooling?
Check out "Tonight's Picks" on Yahoo! TV.
http://tv.yahoo.com/
