double check between postgis and queryByAttribute
theresia freska
frezzz_54 at YAHOO.COM
Tue Mar 20 22:57:02 EDT 2007
hello, can someone pls check my code? just wonder if i use too much resource. seems like i do double check here, between postgis and queryByAttribute.
does mapserver do this kind of check in the queryByAttribute? if yes, how can i access it?
thank you.
if ($_POST['mode'] == "itemnquery") {
$qstring = $_POST['qstring'];
$inputLayer = array('Highway', 'Street');
//check whether the query layers are active or not
if (array_intersect($inputLayer, $listLayer) != $inputLayer) {
echo "<script language='Javascript'>alert('Query layer is not active.')</script>";
} else {
//if yes, check if user's input returns >1 name
if ($_POST['qstring']) {
$conn = pg_connect("host=".$host." dbname=".$database." user=".$user." password=".$password) or die ("Error connect!");
$result = pg_query("select distinct road, class from tbRoad where road like '%$qstring%'");
$m = 0;
while ($row = pg_fetch_row($result)) {
$res[$m] = $row;
$m++;
$result_table = makeTable($res);
//if it returns only 1 name, display the query map
if (count($res)==1) {
for ($k=0; $k<count($inputLayer); $k++) {
$qLayer = $map->getLayerByName($inputLayer[$k]);
$qry = "road LIKE '%" . $qstring . "%'";
@$qLayer->queryByAttributes("road", $qry, MS_MULTIPLE);
$showquery = TRUE;
drawQueryRes();
} else {
echo "<script language='Javascript'>alert('Please fill the appropriate field.')</script>";
It's here! Your new message!
Get new email alerts with the free Yahoo! Toolbar.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070320/a70b0cf6/attachment.html
