Firefox can't print transparent PNG image from Mapserver
Delfos, Jacob
Jacob.Delfos at MAUNSELL.COM
Wed May 2 19:47:25 EDT 2007
Hi Ei,
I don't have a solution, but it might be helpful to know that this
problem has existed for quite a while in Mozilla (>2 years). It's
nothing to do with your particular setup or printers, I have had the
same issue here.
Perhaps you could merge the images into a single image? This is what I
do for my print layouts.
Regards,
Jacob
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Ei Fujioka
> Sent: 3 May 2007 00:50
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Firefox can't print
> Hi guys,
> This may be a Firefox issue but want to know how you guys
> deal with this
> problem, if any, on your mapper application.
> I got a weird problem that Firefox can't print a PNG image with
> transparent background which is retrieved from Mapserver.
> It's transparent on the browser, and so is it with [Print Preview].
> But when I print this, the PNG image covers the legend and background
> images (the transparent background turns to white).
> To make things simple, I copied the PNG image in question along with
> legend and some background map images into a quite simple HTML.
> http://seamap.env.duke.edu:8888/dev/mapservice/googlemaps/test.html
> Here, the combination of points and lines is the PNG with transparent
> background. Should look OK on your browser.
> Below is a screen shot of Firefox's [Print Preview].
> http://seamap.env.duke.edu:8888/dev/cache/misc/firefox_cant_pr
> Still has transparent background, but when printed, it doesn't.
> IE doesn't have this problem. It prints as seen on the browser.
> Do you have any idea what's wrong?
> Is it just a Firefox bug? Any workaround? Should use GIF?
> # I thought Firefox provided great support for PNG...
> <Excerpt from Mapfile>
> IMAGETYPE png
> OUTPUTFORMAT
> NAME png
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE PC256
> EXTENSION "png"
> END
> RESOLUTION 72
> TRANSPARENT ON
> <Mapserver version>
> MapServer version 4.2.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> <Environment>
> ver 1.5.0.11 on Windows 2000
> ver 1.5.0.11 on Windows Xp
> A color printer and a B/W printer
> Thanks,
> Ei
> Ei Fujioka
> Research Associate
> Duke University
> (919) 613-8021
> efujioka at duke.edu
This email and any attachments are intended solely for the named recipient and are confidential. The copying or distribution of them or any information they contain by anyone other than the named recipient is prohibited. If you have received this document in error, please notify the sender and delete all copies from your computer system and destroy all hard copies. It is the recipient's responsibility to check this email and any attachments to this email for viruses before use.
