join with dbf file
Richard Greenwood
richard.greenwood at GMAIL.COM
Mon May 14 10:14:06 EDT 2007
On 5/14/07, Fischer, Brian <bfischer at houstonengineeringinc.com> wrote:
> Rich,
> You are correct, I am just trying to display attribute data from the
> join table.
> -Brian
I don't know if this will help, but here is an example of displaying
attribute data from a one-to-many relationship:
LAYER
NAME "join"
GROUP "ownership"
STATUS ON
TYPE POLYGON
PROJECTION
"init=epsg:2241" # NAD83 / Idaho East (ftUS)
END
DATA "join"
HEADER "attribute_header.html"
FOOTER "attribute_footer.html"
TEMPLATE "attribute_display.html"
JOIN # JOIN no longer lives inside of CLASS or inside a QUERY object
NAME "cats"
TABLE "/Inetpub/wwwroot/mapserver/fc/data/cat.DBF"
FROM DESCRIPTOR
TO PIDN
TYPE one-to-many # multiple
TEMPLATE cat.html # required only for one-to-many joins
END # of JOIN Object
CLASSITEM "CLERK_REC"
CLASS
Name "Lot and Parcel Lines"
SYMBOL "Solid"
OUTLINECOLOR 0 0 0
SIZE 2
END # class
END # layer join
cat.html:
<TR><TD>[cats_ACRES] </TD><TD>Acres </TD><TD>[cats_CATEGORY]</TD></TR>
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
