WG: [UMN_MAPSERVER-USERS] WG: OGR, ODBC join on OGR, ODBC
Arnd Wippermann
arndw at WTAL.DE
Mon May 14 17:22:29 EDT 2007
Hello Frank,
many thanks for your hint. It runs perfect.
That's the way to join ODBC-tables:
the ovf-file GEOLINES.ovf in the same directory as the mapfile
<OGRVRTDataSource>
<OGRVRTLayer name="LINESLYR">
<SrcDataSource>ODBC:GEOOBJEKT,GEOLINES</SrcDataSource>
<!-- not needed. Instead using SrcSQL
<SrcLayer>LINESLYR</SrcLayer>
<SrcSQL>SELECT * FROM GEOLINES LEFT JOIN GEOLINES_TREPPE ON
GEOLINES.ID_GEOOBJEKT = GEOLINES_TREPPE.ID_GEOOBJEKT;</SrcSQL>
<!-- apparently not needed, because the column position holds all the
info
<GeometryType>wkbLineString</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="WKT" field="position"/>
</OGRVRTLayer>
</OGRVRTDataSource>
and the interesting part of the mapfile
LAYER
NAME 'LINES'
GROUP 'LINES'
TYPE LINE
STATUS ON
CONNECTION 'GEOLINES.ovf'
CONNECTIONTYPE OGR
DATA 'LINESLYR' # <OGRVRTLayer name="LINESLYR">
CLASSITEM 'STUFENANZAHL' # this is the column from the joined table
GEOLINES_TREPPE
CLASS
NAME 'Treppen'
EXPRESSION ([STUFENANZAHL] > 100)
STYLE
COLOR 64 64 64
WIDTH 5
END
STYLE
COLOR 255 128 0
WIDTH 3
END
END
CLASS
NAME 'SONST'
STYLE
COLOR 0 255 255
WIDTH 2
END
END
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
-----Ursprüngliche Nachricht-----
Von: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Im
Auftrag von Frank Warmerdam
Gesendet: Montag, 14. Mai 2007 22:49
An: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: Re: [UMN_MAPSERVER-USERS] WG: OGR, ODBC join on OGR, ODBC
Arnd Wippermann wrote:
> Hello,
> I have an Access DB to hold the geometry as WKT-String and attributes
> of a line layer and use OGR with ODBC to display my features.
> GEOLINES the line geometry as WKT-String
> GEOLINES_TREPPE the attributes for the lines
> GEOMETRY_COLUMNS the configuration of table, objecttyp and srs
> I have no problem with
> CONNECTIONTYPE OGR
> CONNECTION 'ODBC:GEOOBJEKT,GEOLINES'
> to display my lines on the map.
> But I want to classify my lines with values from the table
GEOLINES_TREPPE.
> In Access the following query delivers what I expect:
> When I use this query for my GEOLINES layer in a mapfile and add the
> DATA-line, nothing will display and also no error message is given.
Arnd,
I believe the problems is that the ODBC driver does not know what column in
your select result to use as the geometry since it finds this in the
GEOMETRY_COLUMNS table. But this mechanism only works for simple tables,
not custom selects.
One option might be to use a VRT wrapper for the ODBC datasource to
accomplish this instead of trying to use GEOMETRY_COLUMNS.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGeo, http://osgeo.org
