Problems with Mapserv and ArcSDE layer
Ivano Picco ivano.picco at AQUPI.TK
Thu May 17 09:38:50 EDT 2007
  After many tests I found a workaround to the "cgi process   zombified   when you made an
ArcSDE request by WMS" problem.
I launch a "timeout" shell script (like this:
http://www.shelldorado.com/scripts/cmds/timeout) inside a simple wrapper script.
This timeout script  executes a mapserv cgi process and launchs a watchdog who kills
the "zombie" after a timeout .  As you can see this is not a good solution for the problem.
My tests reveal   an improvement on number of requests  per second (+35%), because the
timeout kills all the processes who fill the apache request stack.
I think I will reach the maximun performance only when I can use cgi without a wrapper.
I hope you will solve this soon,
Best regards,
Ivano.
