WFS: Problems with multipolygons
Fernando Simon fsimon at UNIVALI.BR
Sun May 20 23:15:08 EDT 2007
Hi Teemu,
    Sorry for the delay to reply you message.
    About this error, did you already tried to draw a map in CGI mode,
just to test all the polygons? Dis you already try to restrict the
objects in the data definition. Like: "GEOLOC FROM (SELECT ID_X, GEOLOC
TABLE_X WHERE ID_X = XXXXX) USING UNIQUE ID_X". Where the XXXXX is the
id for the object that are not draw?
    About the objects, all have the same attributes, like SRID, GTYPE
and ETYPE?
    I'm a not WFS specialist, I believe that the Bart can help in this
way, I can help with the Oracle relate issues.
    Best regards.
Fernando Simon
UMN Mapserver and Oracle Spatial developer
Teemu Makela wrote:
> More information related to this issues.
> I tested the same layer through WMS and WFS. Layer works fine through WMS
> but WFS omits all execpt one part of the multipolygon. At below you will
> also find the mapfiles.
> See attached image "MapServer_WMS" which contains a multipolygon (5 parts
> with label 10404).
> See another attached image "MapServer_WFS_missing_polygons_labels_from_WMS".
> On this image only one piece of the multipolygon is visible. Labels are from
> WMS layer just to show that there should be more data (label is variable
> ID_X from mapfiles).
> Is it so that MapServer's WFS just cannot handle multipolygons or am I doing
> something wrong?
> ---- Mapfiles ----
> WMS layer drawing polygons:
> LAYER
> 	  NAME XXXXXX
> 	  TYPE POLYGON
> 	  STATUS ON
> 	  CONNECTIONTYPE oraclespatial
> 	  CONNECTION "xxx/xxx at xxx.xxx.com"
> 	  DATA "GEOLOC FROM TABLE_X USING UNIQUE ID_X"
> 	  PROJECTION
> 	    "init=epsg:2393"
> 	  END
> 	  CLASS
> 	    NAME "GEOMETRIA"
> 	    STYLE
> 	      OUTLINECOLOR 200 200 200
> 	      COLOR 255 0 0
> 	    END
> 	  END
> END
> WFS layer trying to draw polygons:
> LAYER
>   NAME XXXXXX
>   METADATA
>     "wfs_title"				"XXXXXXXX"
>     "wfs_extent"				"XXX XXX XXX XXX"
>     "gml_featureid"			"ID_X"
>     "gml_include_items"			"all"
>   END
>   TYPE POLYGON
>   STATUS ON
>   PROJECTION
>     "init=epsg:2393"
>   END
>   DUMP TRUE
>   CLASS
>     NAME "GEOMETRIA"
>     STYLE
>     END
>   END
> END
> Teemu
