OGR and ODBC
Frank Warmerdam warmerdam at POBOX.COM
Wed May 23 19:34:09 EDT 2007
Sture Dingsøyr wrote:
> Hi there...
> Been using OGR to fetch some WKT data from an MS SQL table. This works
> fine...but a few om my records just wont show up in the map.
> The layer is of type LINE.
> Have the WKT directly in a FEATURE LAYER and then it is drawn perfectly..
> Any ideas why a couple of my record just wont be drawn in the map?
Sture,
I don't know why it isn't working.  Is there any pattern to the geometries
that don't work?  Such as being the longest ones?
If you were able to reproduce the same problem with an .mdb file, it would
be easy to file a bug report that the GDAL team could investigate.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
