Combining layers into fewer tiles to reduce the number of Apache GETs
Samuel Doyle sdoyle_2 at YAHOO.COM
Wed May 23 23:11:49 EDT 2007
Hi does providing the grouping that you add actually condense the number of
tiles that are generated? We are using kaMap on the client side for
retrieving the map.
On Wed, 23 May 2007 22:09:59 -0400, Ed McNierney <ed at TOPOZONE.COM> wrote:
>André -
>Your description sounds a little odd.  It is common for MapServer
applications to contain many dozens of shapefiles.  There may be one
shapefile per layer, but many layers combined into a GROUP with that
keyword.  And a given MapServer request can specify as many layers - in one
GET request - as needed.
>From your description, simply adding a GROUP EVERYTHING (for example) to
each LAYER object, then making a single request for the layer EVERYTHING
would do just what it seems you are describing.
>-      Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com / Maps a la carte, Inc.
>73 Princeton Street, Suite 305
>North Chelmsford, MA  01863
>Phone: 978-251-4242, Fax: 978-251-1396
>ed at topozone.com
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Andre Lockhart
>Sent: Wednesday, May 23, 2007 9:50 PM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] Combining layers into fewer tiles to reduce
>We have a MapServer application that uses ESRI shapefiles. There is a
different shapefile for land, street, city name, railroads, parks, etc.
MapServer creates and overlays tiles/layers for each and decorates them
according to the mapfile.
>The problem is that it requires over 200 GETs on the web server to pull all
these layers/tiles down to the client and render them.
>Since all these layers are static and never need to be toggled on/off, we
would like to 'flatten' them into one layer. This would reduce the number of
GETs by almost an order of magnitude.
>Does anyone know how to do this while keeping the 'decoration' (like
colors, fonts, etc.) specified in the mapfile?
>Thanks!
>  <http://www.covaluate.com/>
>         André Lockhart, President
>         andre at CoValuate.com
>         510.333.7189
