labels truncated at 256 chars
Francesco Sozzi
fsozzi at INTERCAD.CH
Thu May 24 02:31:29 EDT 2007
Hi Steve and Fernando,
Thanks for your support and fast answer.
I am using Oracle Spatial 9i on Mapserver 4.10.1 compiled by Visual Studio
.NET 2003 (Everithing very stable from several years).
Do you think it is something related to Oracle?...
Here you are my layer definition:
LAYER
NAME "Voli"
TYPE POINT
CONNECTIONTYPE oraclespatial
CONNECTION "ti_externals/avs at franz"
DATA "GEOM FROM (SELECT fid,label,geom FROM ic_voli) USING UNIQUE fid"
LABELITEM "label"
STATUS DEFAULT
CLASS
NAME 'Volo'
SYMBOL 'circle'
SIZE 10
COLOR 255 0 0
TEMPLATE "templates/default.html"
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 8
ANGLE AUTO
BUFFER 2
OFFSET 0 -10
FORCE TRUE
WRAP '@'
END
END
END
Best regards
Francesco
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, May 24, 2007 6:47 AM
Subject: Re: [UMN_MAPSERVER-USERS] labels truncated at 256 chars
I created a quick test case using inline features and can render more than
256 chars, 322 in my example. Must be a data driver issue. What data source
are you using? With shapefiles I thought the limit in a single column was
256 chars.
Steve
>>> Steve Lime <Steve.Lime at DNR.STATE.MN.US> 05/23/07 5:49 PM >>>
I didn't think this was a limitation, lemme check and reply back...
Steve
>>> Francesco Sozzi <fsozzi at INTERCAD.CH> 05/23/07 7:20 AM >>>
Hi All,
Anybody has a workaround to display labels longer than 256 chars?
Or may be any suggestions on where to modify mapserver code?
Best regards
Francesco
__________ Informazione NOD32 2287 (20070523) __________
Questo messaggio è stato controllato dal Sistema Antivirus NOD32
http://www.nod32.it
