labels truncated at 256 chars
Fernando Simon fsimon at UNIVALI.BR
Thu May 24 08:56:57 EDT 2007
Hi Francesco, and Umberto,
    Yes, this is the correct way to increase the text size. I believe
that exists a bugreport about it.
     Thanks Umberto for the quickly reply. Here the clock time for me
was 04:00 when the issue started and finished.
     Best regards.
Fernando Simon
UMN Mapserver and Oracle Spatial developer
Francesco Sozzi wrote:
> Hi Umberto!
> Great!!! It works!
> Thank you very much for suggestion.
> Best regards
> Francesco
> ----- Original Message ----- From: "Umberto Nicoletti"
> <umberto.nicoletti at GMAIL.COM>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Thursday, May 24, 2007 8:46 AM
> Subject: Re: [UMN_MAPSERVER-USERS] labels truncated at 256 chars
> This is almost surely a limitation of oracle spatial.
> You could try to recompile mapserver after editing the
> maporaclespatial.c file at about line 58 where it says:
> #define TEXT_SIZE                  256
> and set TEXT_SIZE to a higher number.
> HTH,
> Umberto
> On 5/24/07, Francesco Sozzi <fsozzi at intercad.ch> wrote:
>> Hi Steve and Fernando,
>> Thanks for your support and fast answer.
>> I am using Oracle Spatial 9i on Mapserver 4.10.1 compiled by Visual
>> Studio
>> .NET 2003  (Everithing very stable from several years).
>> Do you think it is something related to Oracle?...
>> Here you are my layer definition:
>> LAYER
>>  NAME "Voli"
>>  TYPE POINT
>>  CONNECTIONTYPE oraclespatial
>>  CONNECTION "ti_externals/avs at franz"
>>  DATA "GEOM FROM (SELECT fid,label,geom FROM ic_voli) USING UNIQUE fid"
>>  LABELITEM "label"
>>  STATUS DEFAULT
>>  CLASS
>>   NAME 'Volo'
>>   SYMBOL 'circle'
>>   SIZE 10
>>   COLOR 255 0 0
>>   TEMPLATE "templates/default.html"
>>   LABEL
>>    COLOR 0 0 0
>>    TYPE TRUETYPE
>>    FONT arial
>>    SIZE 8
>>    ANGLE AUTO
>>    BUFFER 2
>>    OFFSET 0 -10
>>    FORCE TRUE
>>    WRAP '@'
>>   END
>>  END
>> END
>> Best regards
>> Francesco
>> From: "Steve Lime" <Steve.Lime at DNR.STATE.MN.US>
>> Sent: Thursday, May 24, 2007 6:47 AM
>> I created a quick test case using inline features and can render more
>> than
>> 256 chars, 322 in my example. Must be a data driver issue. What data
>> source
>> are you using? With shapefiles I thought the limit in a single column
>> was
>> 256 chars.
>> Steve
>> >>> Steve Lime <Steve.Lime at DNR.STATE.MN.US> 05/23/07 5:49 PM >>>
>> I didn't think this was a limitation, lemme check and reply back...
>> Steve
>> >>> Francesco Sozzi <fsozzi at INTERCAD.CH> 05/23/07 7:20 AM >>>
>> Hi All,
>> Anybody has a workaround to display labels longer than 256 chars?
>> Or may be any suggestions on where to modify mapserver code?
>> Best regards
>> Francesco
>> __________ Informazione NOD32 2287 (20070523) __________
>> Questo messaggio  è stato controllato dal Sistema Antivirus NOD32
>> http://www.nod32.it
> http://www.nod32.it
