Layer display order (z-index)?
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue May 29 17:57:42 EDT 2007
Layers are rendered in the order they appear in the mapfile so I'm not sure how the POI symbols
could be rendered below the line work. You could try turning them into annotation instead of point
layers since annotation is always drawn last. You might need to post your mapfile...
Steve
>>> On 5/29/2007 at 4:06 AM, in message <C69E8A2815154DF2B5E9416C95DA580F at jackey>,
Jackey Cheung <cheung.jackey at GMAIL.COM> wrote:
> Greetings!
> I've put some roads, polygons and poi to my map, their order in the map file
> is: polygon layers go first, then road layers, and the poi layer is the last.
> A picture is generated like this: http://www3.mapasia.com/jackout/mapserv.png
> As you can see, those 2 POI icons are covered by roads, can I make those POI
> icons always on top of everything else in the map?
> I've tried re-ordering layers in the map file, but the icons are kept covered
> by roads.
