flash swf polygon highlight
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue Oct 2 10:05:17 EDT 2007
Shannon,
I have entered a bug on it http://trac.osgeo.org/mapserver/ticket/2336
and will add the instances names. If you could cc yourself to that bug
and possibly help with tests/input, that would be great.
Best Regards,
Shannon Scott wrote:
> Anyone with interest,
> I have made limited progress on this issue.
> It turns out that the polygons are created in the swf output as
> instances of object Button. These button instances do not have instance
> names associated with them so they cannot be referenced in ActionScript
> ( I guess ).
> I am trying to alter the mapswf.c to add names to the button instances.
> I am not a c developer, so I am struggling.
> Any help or advice would be greatly appreciated.
> Thank you.
> Shannon
>> Hello,
>> I have a flash map. I have built an application so that when the
>> person mouses over the map - the highlighted polygon ( under mouse )
>> will highlight part of the web page - with corresponding information.
>> I would like to also make it so when the web page is moused over the
>> respective polygon will also become highlighted. I am able to access
>> the polygon attributes through the Element array.
>> Is there a way to highlight the polygon using actionscript - if I know
>> the Element array index number?
>> Any help or pointers are appreciated.
>> Thank you.
>> Shannon
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
