MS 5.0 crashes on pdf output, 4.10.2 is OK
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Wed Oct 3 05:41:21 EDT 2007
I've posted a patch that solves this issue here:
http://trac.osgeo.org/mapserver/ticket/2338
Please let me know if it works.
Umberto
On 10/1/07, Maciej Sieczka <tutey at o2.pl> wrote:
> MS 5.0 crashes on a map file with output type set as:
> IMAGETYPE pdf
> OUTPUTFORMAT
>   NAME pdf
>   DRIVER pdf
> END
> Examples:
> ./shp2pdf -m pdf.map -o pdf_ms5.pdf
> *** glibc detected *** free(): invalid next size (fast):
> 0x08254f00 ***
> ./shp2img -m pdf.map -o pdf_ms5.pdf
> 0x08179608 ***
> The same map file works OK with shp2img and shp2pdf from MS
> 4.10.2.
> Both MS 4.10.2 and 5.0 built and running against the same
> libraries, on the same machine. Both source codes were
> configured with exactly the same switches.
> Ubuntu Dapper 32bit, using PDFLib-Lite 7.0.2. If more
> details are needed please let me know.
> Maciek
