problem invoking WCS: "no template"???
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Thu Oct 11 07:35:36 EDT 2007
Through offline discussions with Jeff DLB, it looks like his MapServer is not built --with-wcs.
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Piero Cavalieri
> Sent: 11 October, 2007 3:52 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] problem invoking WCS: "no
> template"???
> P.S. Maybe you have some template related keyword, in your
> map file, which doesn't make sense, in a WCS.
> Bye
> Piero
> Sent: mercoledì 10 ottobre 2007 18.06
> template"???
> > I am trying to make the Web Coverage Service (WCS) feature work.
> > However, GetCapabilies and GetCoverage requests both respond with
> > "mapserv(): Web application error. No template provided."
> > No doubt I have made some basic configuration error, but I
> cannot find
> > my problem. The Web Map Service (WMS) functionality using the same
> > mapfile does work.
> > Here are the parts of my mapfile that I believe are relevant to WCS:
> > # Added for WCS support
> > OUTPUTFORMAT
> > NAME GEOTIFF
> > DRIVER "GDAL/GTiff"
> > MIMETYPE "image/tiff"
> > IMAGEMODE "BYTE"
> > EXTENSION "tif"
> > END
> > # TEST WCS feature
> > LAYER
> > NAME "airstiff"
> > TYPE RASTER
> > DUMP TRUE
> > METADATA
> > "wcs_title" "AIRS TIFF Coverage"
> > "wcs_nativeformat" "tiff"
> > END
> > STATUS off
> > PROJECTION
> > "init=epsg:4326"
> > END
> > DATA "/sivo/data/soar/airs/2007/01/04/12/bt.tiff"
> > END
> > NOTE: The same floating-point GeoTIFF (bt.tiff) is
> correctly read and
> > classified by the WMS component.
> > Is there something missing in my mapfile? This document:
> > http://mapserver.gis.umn.edu/docs/howto/wcs_server/#d45e65
> > claims that four conditions must be satisfied, as I believe I have
> > done:
> > Data source is of raster type that is processed
> using GDAL (e.g
> > GeoTIFF, Erdas Imagine, ...)
> > LAYER NAME must be set
> > LAYER TYPE is RASTER
> > LAYER DUMP parameter set to TRUE
> > Thanks for any help,
> > Jeff DLB
> Jeff,
> What does your request URL look like? Did you include
> service=WCS in the request?
> ..Tom
