Mapserver 5 with Oracle10g or ArcSDE 9.2
José Ramón López
joseramonlopez at GMAIL.COM
Thu Oct 11 10:32:56 EDT 2007
Hi Tim
I used it before too, but its send to me a blank image.
This is the output command:
C:\ms4w\tools\mapserv>shp2img.exe -m ..\..\maps\map\wms.map -i png -o
prueba.png -all_debug 4
msDrawMap(): Drawing Label Cache, 0.000s
msDrawMap() total time: 0.000s
msFreeMap(): freeing map at 0145B630.
No errors?
Thxs
2007/10/11, Nolte, Tim <Tim.Nolte at ipcswirelessinc.com>:
> Jose,
> When I was working trying to get Oracle 10g working with MapServer I
> turned to using SHP2IMG for testing against my mapfile. So on the
> server/machine you have MapServer installed on, call shp2img...specifying
> your mapfile and make sure to tell it to return debugging information. This
> has helped to clue me in on issue with my mapfile/mapserver.
> Timothy J Nolte - tnolte at ilpcs.com
> Associate Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS: 616-706-2438
> Fax: 616-554-6484
> Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of José Ramón López
> Sent: Thursday, October 11, 2007 6:12 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Mapserver 5 with Oracle10g or ArcSDE 9.2
> Hi list again.
> Im trying to configure a new server with mapserver 5.0 connect it with
> Oracle 10g or ArcSDE 9.2 , ussing the ms4w package (MS4W PHP5 Base
> Installer v2.2.6 )
> I have done all that i have read in the instructions.
> The problems is that mapserver sends to me a blank image, and with some
> clients it send me a error.
> I have installed in that machine Oracle 10g client.
> This is the configuration of the layer.
> LAYER
> NAME AFOROS
> GROUP "Redes.Ctrl"
> TYPE POINT
> CONNECTIONTYPE oraclespatial
> CONNECTION 'user/pass at SDE'
> DATA 'SHAPE FROM AFOROS USING UNIQUE OBJECTID'
> DUMP TRUE
> DEBUG ON
> PROCESSING "CLOSE_CONNECTION=DEFER"
> TRANSPARENCY 0
> PROJECTION
> "init=EPSG:23030"
> END
> CLASS
> STYLE
> SYMBOL "circle"
> SIZE 10
> COLOR 255 85 0
> END
> NAME 'Aforos'
> END
> METADATA
> "wms_title" "Aforos"
> "wms_group_title" "Redes de Control"
> "wms_keywordlist" "WMS Aforos"
> "wms_srs" "EPSG:23030"
> "wms_extent" "154590 4062740 579080 4300000"
> END
> END
> In httpd.conf i have declared the system varibles:
> #Oracle Spatial
> SetEnv PATH "C:/oracle10gclient/bin"
> SetEnv TNS_ADMIN "C:/oracle10gclient/network/admin"
> SetEnv ORACLE_SID "SDE91 SDE92 GLOBAL"
> SetEnv ORACLE_BASE "C:/oracle10gclient"
> SetEnv LD_LIBRARY_PATH "C:/oracle10gclient/lib"
> And the file C:/oracle10gclient/network/admin/tns_admin.ora
> SDE =
> (DESCRIPTION =
> (ADDRESS_LIST =
> (ADDRESS = (PROTOCOL = TCP)(HOST = 172.19.132.93)(PORT = 1521))
> (CONNECT_DATA =
> (SERVICE_NAME = SDE)
> In the access.log nothing appears about the getmap and layer request ,
> only the getcapabilites, the same happens in the ms_error.txt
> In access.log
> [11/Oct/2007:11:58:58 +0200] "GET
> /cgi-bin/wms?REQUEST=GetCapabilities&SERVICE=WMS&&EXCEPTIONS=XML HTTP/1.1"
> 200 5789
> 127.0.0.1 - - [11/Oct/2007:11:58:59 +0200] "GET
> /cgi-bin/wms?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=
> 1.1.1&EXCEPTIONS=XML HTTP/1.1" 200 5789
> and in the ms_error file:
> [Thu Oct 11 12:04:26 2007].828000 loadParams() QUERY_STRING:
> [Thu Oct 11 12:04:26 2007].875000 msLoadMap(): 0.047s
> [Thu Oct 11 12:04:26 2007].875000 CGI Request 1 on process 2288
> [Thu Oct 11 12:04:27 2007].62000 loadParams() QUERY_STRING:
> REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1&EXCEPTIONS=XML
> [Thu Oct 11 12:04:27 2007].93000 msLoadMap(): 0.031s
> [Thu Oct 11 12:04:27 2007].93000 CGI Request 1 on process 532
> I tried to make the request through explorer like
> http://localhost/cgi-bin/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GETMAP&LAYERS=AFOROS&SRS=EPSG:23030&BBOX=154590.0,4062740.0,579080.0,4300000.0&WIDTH=861&HEIGHT=482&FORMAT=image/png&STYLES=default&TRANSPARENT=TRUE<
> but sends to me a blank image.
> Thats anybody knows what is happening?
> Thxs and sorry for my english
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071011/5db2ca0e/attachment.html
