Problem with java mapscript
maurosa at iol.it
maurosa at IOL.IT
Thu Oct 11 13:48:36 EDT 2007
Hi list
I am using mapserver 5.0 with java mapscript.
I use oracle spatial 10g.
I have problems with long string (longer then 2k)
used to specify complex data sql connection query or filter.
When mapscript execute for instance setFilter it crashes.
I suspect there is a general issue with long string.
The same string used directly in the mapfile works correctly.
It is probably a mapscript memory allocation problem.
While I can use an oracle view to avoide the problem for the connection query, I do not know how to avoide it with the filter, because it is known only at run time.
The filter can be something like:
CODE IN ('1','2','3'....very long string ... '1000')
Can this be set as a bug?
Thank you for any suggestion
Mauro Sartori
Leggi GRATIS le tue mail con il telefonino i-mode di Wind
http://i-mode.wind.it/
