Antwort: [UMN_MAPSERVER-USERS] Problem with java mapscript
Benedikt Rothe umn-ms at HYDROTEC.DE
Fri Oct 12 02:27:01 EDT 2007
Hi Mauro
Problably there is a kind of mapserver bug.  As far as I know
maspserver-oracle supports a maximum of 6000 chars for SQL-statement
and the code doesn't handle overflow's gracefully.
On the other hand: Even if mapserver could handle SQL-strings of
arbitrary length, you still have to deal with the Oracle-Limit
of 1000 elements in the "CODE IN (...)"-Expression.
(http://download-uk.oracle.com/docs/cd/A87861_01/NT817EE/server.817/a85397/expressi.htm#1029285)
Maybe you are forced to look for a different approach anyway?
Benedikt Rothe
UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
11.10.2007 19:48:36:
> Hi list
> I am using mapserver 5.0 with java mapscript.
> I use oracle spatial 10g.
> I have problems with long string (longer then 2k)
> used to specify complex data sql connection query or filter.
> When mapscript execute for instance setFilter it crashes.
> I suspect there is a general issue with long string.
> The same string used directly in the mapfile works correctly.
> It is probably a mapscript memory allocation problem.
> While I can use an oracle view to avoide the problem for the
> connection query, I do not know how to avoide it with the filter,
> because it is known only at run time.
> The filter can be something like:
> CODE IN ('1','2','3'....very long string ... '1000')
> Can this be set as a bug?
> Thank you for any suggestion
> Mauro Sartori
> Leggi GRATIS le tue mail con il telefonino i-mode? di Wind
> http://i-mode.wind.it/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071012/2d9a6cc6/attachment.html
