msLayerObj.whichShapes() behavior?
Tamas Szekeres
szekerest at GMAIL.COM
Fri Oct 12 03:18:15 EDT 2007
That should correspond to the projection of the layer. You might want
to utilize RectObj.project if you have the rect in some other
projection system.
Best regards,
Tamas
2007/10/11, Damien Corpataux <damien.corpataux at camptocamp.com>:
> Hi,
> I have a question about LayerObj.whichShapes(RectObj) behavior:
> do the RectObj coordinates have to suit the layer projection, or the
> mapfile projection?
> Thanks in advance,
> Damien Corpataux
> Camptocamp SA
> Damien Corpataux
> PSE A
> CH-1015 Lausanne
> +41 21 619 10 22 (Direct)
> +41 21 619 10 10 (Centrale)
> +41 21 619 10 00 (Fax)
> P Please consider the environment
> Do you really need to print this email?
