ESRI Personal GDB / OGR not working
Frank Warmerdam
warmerdam at POBOX.COM
Mon Oct 15 11:08:48 EDT 2007
Flavio Hendry wrote:
> Hi all [hello Frank, me again]
> No way to get something displayed and everything should be correct (same
> layer as MapInfo file in same MapFile with same settings works, means
> parcels drawn as it should, mdb creates blank image); any idea ??? (mdb
> is ESRI ArcGIS 9.1).
> msOGRFileClose(f:/temp/data/cademonti.mdb,1).
> [Mon Oct 15 16:34:11 2007].203000 msDrawMap(): Layer 2 (Parcelle), 0.078s
> [Mon Oct 15 16:34:11 2007].203000 msOGRFileOpen(cademonti.mdb)...
> [Mon Oct 15 16:34:11 2007].203000 OGROPen(f:/temp/data/cademonti.mdb)
> [Mon Oct 15 16:34:11 2007].234000 msOGRLayerClose(cademonti.mdb).
Flavio,
So the shp2img call for which you provided this debug output did not
actually draw any features? That does seem odd.
If you can provide a mapfile+symbolfile+mdb so I can test with shp2img,
I'd be happy to look into the problem briefly.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
