shp2img failing on super-basic mapfile
Daniel Morissette
dmorissette at MAPGEARS.COM
Mon Oct 15 13:44:42 EDT 2007
Webb Sprague wrote:
> I am trying to generate an image from the following mapfile, but I
> keep getting the following:
> MAPSCRIPT[0]$ shp2img -m map2 > foo
> msEvalRegex(): Regular expression error. String (map2) failed
> expression test. <br>
The "failed expression test" in this case is on the mapfile filename
itself: "map2" is missing a ".map" extension.
Rename "map2" to "map2.map" and try again.
Daniel
Daniel Morissette
http://www.mapgears.com/
