shp2img failing on super-basic mapfile
Gregor Mosheh
gregor at HOSTGIS.COM
Mon Oct 15 13:44:52 EDT 2007
Webb Sprague wrote:
> MAPSCRIPT[0]$ shp2img -m map2 > foo
> msEvalRegex(): Regular expression error. String (map2) failed
> expression test. <br>
Mapfiles must end in .map
Try renaming it to map2.map and try again.
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
