FONTSET problem on mac os x - empty rectangles in the image
Webb Sprague
webb.sprague at GMAIL.COM
Mon Oct 15 23:53:33 EDT 2007
I am attaching the file, but this didn't fix the problem. You can see
the empty boxes.
Thx, though ;)
-W
On 10/15/07, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Is this a transparent overlay layer? is IMAGECOLOR 0 0 0? if so then
> that color is transparent and you leters are also transparent. If that
> is the case change your label COLOR 1 1 1 and it should fix the problem.
> -Steve
> Webb Sprague wrote:
> > Hi again
> > I am trying to get labels based on a the "name" field in a postgis
> > table (of GNIS placenames). Everything works great (the overlay, the
> > triangle symbol, etc), but in the image, I get empty boxes where the
> > letters should be (though I get a one-to-one box to letter). If
> > anyone can help, I would sure appreciate it. (I am running a generic
> > mapserver from installed by fink.)
> > Here is the view definition in sql:
> > SELECT placenames.gid AS oid, placenames.name, placenames.desig,
> > placenames.elev, placenames.the_geom
> > FROM placenames
> > WHERE placenames.desig::text = 'airport'::text
> > ORDER BY placenames.gid;
> > Here is the my font file (yes, the files do exist):
> > MAPSCRIPT[2]$ cat fonts.list
> > arial /Library/Fonts/ArialHB.ttf
> > arial2 /Library/Fonts/Arial
> > MAPSCRIPT[2]$
> > Here is the layer in my mapfile:
> > LAYER
> > NAME "airports"
> > CONNECTIONTYPE postgis
> > CONNECTION "user=wsprague dbname=or_gis host=localhost"
> > DATA "the_geom from airports_view"
> > STATUS DEFAULT
> > TYPE POINT
> > LABELITEM "name"
> > LABELCACHE ON
> > CLASS
> > NAME "LocationSymbol"
> > SYMBOL "triangle"
> > COLOR 100 100 82
> > LABEL
> > # OUTLINECOLOR 255 255 255
> > # MINDISTANCE 200 # Label only at close range
> > COLOR 0 0 0
> > TYPE TRUETYPE
> > SIZE 12
> > FONT "arial"
> > POSITION cc
> > ANGLE AUTO
> > PARTIALS FALSE
> > END #end label
> > END
> > END
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071015/a1924749/foo.png
