Layer doesn't work in 5.0
Delfos, Jacob Jacob.Delfos at MAUNSELL.COM
Tue Oct 16 21:07:02 EDT 2007
Hi Jørn,
The only thing I noticed (which has nothing to do with the migrating) is that your transparency is set to 0. Because in Mapserver the transparency actually means "opacity", it means your layer is invisible. I do not believe that this is different in version 5 (although the keyword "opacity" has been added).
Try omitting that value, or set to 100.
Regards,
Jacob
» -----Original Message-----
» From: UMN MapServer Users List
» [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Jørn Vegard Røsnes
» Sent: 16 October 2007 21:38
» To: MAPSERVER-USERS at LISTS.UMN.EDU
» Subject: [UMN_MAPSERVER-USERS] Layer doesn't work in 5.0
» Hi all,
» I've just tried to migrate from FWTools1.3.7 / MS 4.9 to
» FWTools1.3.9 / MS
» 5.0.
» The problem is that my PostGIS layer doesn't want to show up in 5.0.
» My layer conf is below.
» I've read the migration guide, but can't find the problem.
» http://trac.osgeo.org/mapserver/browser/branches/branch-5-0/ma
» pserver/MIGRATION_GUIDE.TXT
» Does anyone else see the problem?
» cheers
» Jørn Vegard
» LAYER
»      NAME "layer_20071005_141040"
»      CONNECTIONTYPE POSTGIS
»      CONNECTION "user=postgres dbname=db host=hostname port=5432"
»      DATA "poly from feature using SRID=4326"
»      TYPE point
»      STATUS ON
»      TRANSPARENCY 0
»      DEBUG ON
»      CLASS
»           TEXT (oil-[oid]-[acquisition_time])
»           EXPRESSION ('[timestamp]' == '20071005_141040' AND
» [threshold] >= 0
» AND [threshold] < 100)
»           LABEL
»              FONT arial
»             TYPE TRUETYPE
»             SIZE 8
»             MINDISTANCE 10000
»             POSITION UR
»             ANGLE 30
»             COLOR 0 0 0
»           END
»           STYLE
»              COLOR 224 64 0
»           END
»      END
»      PROJECTION
»         "init=epsg:4326"
»      END
» END
This email and any attachments are intended solely for the named recipient and are confidential. The copying or distribution of them or any information they contain by anyone other than the named recipient is prohibited. If you have received this document in error, please notify the sender and delete all copies from your computer system and destroy all hard copies. It is the recipient's responsibility to check this email and any attachments to this email for viruses before use.
