FW: max size of CSV column
Charlton Purvis cplist at SECONDCREEK.ORG
Wed Oct 17 12:01:11 EDT 2007
Hi, folks:
I sent the following msg. to GDAL, but I'd like to make sure my bases are
covered and that this isn't something that I should be trying to tweak in a
MapServer .h file.
Thanks!
> -----Original Message-----
> From: Charlton Purvis [mailto:cplist at secondcreek.org]
> Sent: Wednesday, October 17, 2007 11:20 AM
> To: 'gdal-dev at lists.maptools.org'
> Subject: max size of CSV column
> Hi, all:
> I have a CSV that I'm pushing through MapServer via an OGRVRTDataSource
> connection.  I'm running into a problem w/ when my CSV column width is
> huge.  Where can I bump up the max size that OGR can handle for a col
> size?
> lon,lat,val
> -85,23,"BIG STRING"
> Where "BIG STRING" may be > 12k characters.
> Even if this looks crazy to pump through a CSV, it works flawlessly
> otherwise!
> Thanks in advance,
> Charlton
