RV: Don't draw GIF/PNG images on wms clients.
Gilles Bassière
gilles.bassiere at MAKINA-CORPUS.COM
Wed Oct 17 13:00:23 EDT 2007
Manuel Ballesteros Cardador wrote:
> Thank Gilles by your response. Now, I have eliminated CONNECTIONTYPE and CONNECTION parameter of the layer to set it to default values and now wms client draw image only when I am moving the image (pan). Do you know the problem?
Without much context, I'm afraid I can't help. The problem seems to be
at interface level since you finally get an image. In order to check
your WMS, you could try to send the request through a simple web
browser. The request would looks like:
http://localhost/cgi-bin/mapserv.exe?map=comarca_wms.map&LAYERS=Limite&TRANSPARENT=true&FORMAT=image/png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application/vnd.ogc.se_inimage&SRS=epsg:23030&BBOX=286421,4210158,400752,4295906&WIDTH=500&HEIGHT=500
or just:
http://localhost/cgi-bin/mapserv.exe?map=comarca_wms.map&mode=map (this
one is not a valid WMS request but usually provide better error messages).
If these requests return an image, then your problem would rather be in
QGIS.
I usually set the "wms_extent" in the layer's metadata. I'm not sure
whether it's compulsory but it might be useful.
Regards,
Gilles
> I have the shapefile in local path, so DATA parameter of layer point to shapefile.
> If I try connect to my local wms server from qgis, it work well but don't draw the image, only when pan it.
> Best regards!
> -----Mensaje original-----
> De: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] En nombre de Gilles Bassière
> Enviado el: miércoles, 17 de octubre de 2007 12:20
> Para: MAPSERVER-USERS at LISTS.UMN.EDU
> Asunto: [UMN_MAPSERVER-USERS] [Fwd: Re: [UMN_MAPSERVER-USERS] Don't draw GIF/PNG images on wms clients.]
> Hi Manuel
> There's something wrong in your layer definition. If I understand your
> OnlineResource parameter, you try to expose a WMS stream with URL
> http://localhost/cgi-bin/mapserv.exe?, right ?
> So you can't feed your layer with the same WMS, it would be client and
> server of the same service.
> Your connection element should point to your datasource (another WMS, a
> shapefile, a postgis DB, etc.).
> Regards,
> Gilles
>> Hi, Im new in MapServer list.
>> I have configured a WMS server and when I try viewing a .map file on
>> wms clients (arcmap, qgis), images are not shown in. I can do zoom,
>> pan, etc but it is not drawn.
>> If I change resourceonline parameter I obtain drawEPP error.
>> Do you have any idea?
>> Thanks in advance!
>> This is the .map file.
>> MAP
>> NAME "COMARCA"
>> STATUS ON
>> EXTENT 286421 4210158 400752 4295906
>> SIZE 600 500
>> SHAPEPATH "./data"
>> IMAGECOLOR 125 125 125
>> UNITS METERS
>> IMAGETYPE PNG
>> WEB
>> IMAGEPATH "./tmp/ms_tmp/"
>> IMAGEURL "./tmp/"
>> METADATA
>> "wms_title" "WMS Adroches" ##required
>> "wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe?"
>> "wms_srs" "EPSG:23030"
>> END
>> END
>> PROJECTION
>> "init=epsg:23030" ##required
>> END
>> LAYER
>> NAME "Limite"
>> STATUS ON
>> DEBUG ON
>> DATA "comarca"
>> TYPE POLYGON
>> CONNECTION "http://localhost/cgi-bin/mapserv.exe?map=comarca_wms.map"
>> CONNECTIONTYPE WMS
>> METADATA
>> "wms_title" "Limite Comarca"
>> "wms_name" "Limite"
>> "wms_server_version" "1.1.1"
>> "wms_format" "image/PNG"
>> END
>> CLASS
>> NAME "Comarca"
>> STYLE
>> COLOR 170 253 172
>> OUTLINECOLOR 199 199 199
>> END
>> END
>> END # Layer
>> END # Map File
Gilles Bassiere
MAKINA CORPUS
30 rue des Jeuneurs
FR-75011 PARIS
http://www.makina-corpus.com
